Where is the Pinephone eMMc?
In a few words, all operating system images that are available for the PinePhone are already "crafted" in a way that puts the boot loader (U-Boot) where it is expected by the mask ROM (also known as Boot ROM or BROM) inside the A64 SoC.  Thus, all that's needed is to simply write an image to a card.
Thanks, dsimic. Yeah, I forgot that Allwinner is pretty straight forward. Other boards not so much, but I don't want to confuse the issue any further, within the context of Pine64 forums.
Cheers,
TRS-80
Protocols, not Platforms
As a side note, here's an interesting issue that I haven't found mentioned anywhere.
After booting from a Micro SD card and writing the image to the eMMC, if you boot the phone (or laptop) again from the same SD card, it might happen that the /boot partition from the eMMC gets mounted in Linux instead of the same, correct /boot partition on the SD card.  Then, if you perform some system changes or updates that alter the contents of /boot, such as updating the kernel packages, you end up with one part of the updates applied to the wrong /boot partition.
The solution is to change the label of the /boot partition on the SD card prior to using it for subsequent boots, so the label is no longer the same as the label of the /boot partition on the eMMC.
Edit: Actually, the same can also happen to the root partition.
  emmc speed via usb? joe1 0 74 04-27-2024, 08:07 PM
Last Post: joe1
  my pinephone melted norayr 6 997 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,131 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 752 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 390 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,919 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,650 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,458 11-16-2023, 05:03 AM
Last Post: DrYak
  eMMC upgrade EuvzO8 5 1,785 11-08-2023, 11:58 PM
Last Post: brken
  Pinephone frame damages Uturn 2 1,053 10-23-2023, 02:49 AM
Last Post: Uturn
