unable to boot from SDCard
have installed eMMC 32 GB and tried with Debian, all OK, start, SSH via Putty, nand-sata-install, boot without SDCard, all fine.
then i understand, that it is 64-Bit and wine32 do not function in this enviroment, what i need, without this = dead Piece of Hardware for me.
So finding Ubuntu-Version (Bionic with 32 Bit)  github.com_bionic-minimal-rockpro64-0.8.3-1141-armhf.img, tried it and
Hurra, it works, with wine32, x2go, xfce, all I want...(alll on SDCard)
Now beeing unfearful, and try to transfer, or make it new with the eMMC, put the image on /tmp and use
dd Cmd, and now all is gone,
i think i had to delete the Debian-System on eMMC, i do not do it,
Now i try to start without eMMC, and some trial of SDCards, with Jumper (north of the intern button)
all combinations, but no more boot is possible,
the LED's at Network-cable are out,
i do not understand the Connection via TTY and serial Connector, i do not have USB Hardware for this,
some other older PC with seriell Connector is perhaps avaiible.
Pleas help me, any suggestions are welcome..
Charles
(12-15-2020, 09:44 AM)Charles Tarkowski Wrote: have installed eMMC 32 GB and tried with Debian, all OK, start, SSH via Putty, nand-sata-install, boot without SDCard, all fine.
Charles
OK - I suspect your flashing of the eMMC was bad, but no matter. Your immediate problem is you cannot boot from any SDcard. You do not need TTY/serial connector/USB ...
Just a freshly burned image on an SDcard:
- remove any eMMC
- NO jumper on 16
- Just the SDcard inserted with an HDMI screen to start
then power on. If you get something working on the screen then you can add a keyboard, network etc connections.
Good luck
That exact what i tried, but.. on HDMI on my 4k-Monitor never seen a signal, tho whole time, is it possible, that some Monitors are not function?, the screen become black, but no char's on it. Is it possible, that there is an other component Boot before SDCard?
(12-16-2020, 12:33 AM)Charles Tarkowski Wrote: That exact what i tried, but.. on HDMI on my 4k-Monitor never seen a signal, tho whole time, is it possible, that some Monitors are not function?,  the screen become black, but no char's on it. Is it possible, that there is an other component Boot before SDCard?
Conceivably your SPI is corrupt - you could try disabling the SPI while you boot (next entry in the wiki)?
If you are not sure your monitor will work that is a slight concern - I would expect most do though. But equally if you try something like an Armbian image then you should see activity on the on board LEDs as well.
The boot sequence is documented here: conceivably you could try rebuild a bootable eMMC via OTG mode but I think trying to get a bootable SDcard would be my first choice.
Thanks a lot, the solution was:
tried some other images, (monitor is still black) without eMMc, one works,
than reinstall eMMc, every time wants a passwort for root i not remember,
so start with jumper, remove it in 2 sec. and the result is:
start from SDCar and eMMc is visible,
so fdisk /dev/emmc..
delete all partions
and the system is so new like a baby
Hurra
  enble boot after power loss/restore dkebler 18 9,597 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 120,653 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 683 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,306 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,393 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,571 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,326 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,163 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,831 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,173 06-09-2022, 10:56 AM
Last Post: pspgarret
