Manjaro system update failed, bricked PinePhone
I received my PinePhone today with manjaro preinstalled.
I wanted to update the os, the system update was stuck for ~1hour in searching update.
So i opened the terminal and run
sudo pacman -Syuu
The update got stuck at an error about perl and default local. I couldn't do nothing, the phone did not respond so after 1 hour I removed the battery.
Now, when I start it the red led lights is showing up, but on the screen... nothing.
I bought an SDXC ScanDisk extreme 64GB, put ubuntu touch on it..and nothing. No red led light, nothing on screen.
I used the Pine64 installer to create the bootable SD card.
The image I downloaded from here: https://ci.ubports.com/job/rootfs/job/rootfs-pinephone/ .
What should I try to make it work?
Thank you.
(11-26-2020, 06:32 AM)jalanga Wrote: Hi,
sudo pacman -Syuu
Thank you.
You can't brick the PinePhone. Fully charge the phone and just use the instructions from the Wiki to write to SD: https://wiki.pine64.org/wiki/PinePhone_I...structions using the current Ubports repo over at https://ci.ubports.com/job/rootfs/job/ro...stemimage/ as the repo you have been using is outdated (it says so at the top of the page).
  PinePhone - boot from microSD laserpyramid 7 596 Yesterday, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 357 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 241 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,278 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,808 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 613 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,377 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 503 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,712 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,988 12-04-2023, 02:14 AM
Last Post: Peter Gamma
