Axolotl on PinePhone / Mobian
Hello there,
from v1.1.0 on the Axolotl Debian arm64 package files can be found in the Release Assets section of the official Axolotl Github page since cross-compiling and packaging is now done fully autmatically via Github workflow.
https://github.com/nanu-c/axolotl/releases
Please be aware that you can only use one primary device/registration in the Signal server world - Axolotl works as such primary device/registration.
And please feel free to post some feedback, if you like, and also check out the Mobian Wiki for Axolotl:
https://wiki.mobian-project.org/doku.php?id=axolotl
Old packages still can be found here on my Github page
https://github.com/nuehm-arno/axolotl-mobian-package
Welcome.
Great stuff, thanks for working it all out and documenting it.
@arno_nuehm Thanks for the guide. Unfortunately for me, Phosh hard crashes when trying to enter the registration PIN.
The keyboard keeps re-opening, then a prompt to "log out" appears, forcing a hard reset.
Lucky you, I can't even get it to build, it always freezes at "npm install" when it's installing(?) node's rxjs. Has anybody gotten it to build successfully recently?
(11-16-2020, 07:05 AM)marcih Wrote: Lucky you, I can't even get it to build, it always freezes at "npm install" when it's installing(?) node's rxjs. Has anybody gotten it to build successfully recently?
I would guess no other than the developer considering this issue on their GitHub.
Hmm, I have seen that issue but it seems to me they're discussing something completely different, there seems to be a different issue with running it but it sounds like they've gotten it to build successfully.
Is it really a "freeze" or is it just taking a bit more time? In my case (around 04.11.2020 - same date for the Mobian nightly image) it took quite a while for "npm install" to finish.
(11-11-2020, 04:25 PM)jed Wrote: @arno_nuehm Thanks for the guide. Unfortunately for me, Phosh hard crashes when trying to enter the registration PIN.
Which UI are you using? With phosh 0.6.0-1, Midori is up again and maybe the registration is working in this setup.
And to be transparent: I only wrote the "Alternative Setup" part and commented/corrected "Manual install".
I'm not quite sure, I left it alone for half an hour or so with no progress, I assumed it was frozen since the little spinning line on the left wasn't moving either. I'll give it a try again tomorrow, leave it be for longer.
Have you tried it? I will have a go with a fresh installation of the fde-image in a few days and give you an update...
I have, with no luck. Interestingly, building the Flatpak went through fine so I don't know what the issue is. Either way, the app is currently not functional anyway, Electron crashes and qmlscene is not bundled in the Flatpak and doesn't seem to recognise the apt-installed copy.
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 2,896 05-17-2024, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 142 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,188 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 181 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,783 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,160 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,911 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 671 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,206 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,970 07-09-2023, 01:37 AM
Last Post: vusra
