Axolotl on PinePhone / Mobian
(11-29-2021, 07:34 AM)Anna Wrote: Axolotl stopped sending / receiving messages two days ago (Deskotp App still works).
In anybody else experiencing problems?
It's working for me, I was able to receive and send messages today.
I got another question though: Are groups (v2) supposed to work by now? I remember initial support for groups v2 being implemented, but apparently I cannot be added to groups and when I try to create a group, none of my contacts show up (only one contact that is not using Signal and whose number I once added, but can't delete). Is it working for anybody else or are groups generally not yet supported after all?
EDIT: Just started Axolotl now and all at once received several messages I had received and written (in the Deskop app) over the past tow days -- but not all of the. In one chat, I only got the messages till 20 hours ago, in another chat, I only receive the messages that I write (again: in the desktop app) but not the replies.
Very strange.
EDIT 2: Restarted Axolotl again and received even more of the missing messages. Remains erratic though, in one chat for example I only got the messages I had received, not the ones I had sent.
Sorry to hear that - again.
One person from the Axolotl Telegram group using the Ubuntu Touch version just confirmed this statement "In one chat, I only got the messages till 20 hours ago"
Sending/receiving is ok.
But I think, it's a problem regarding the new fix in v1.0.8... I will keep you posted.
Edit: Sadly, even on UT receiving is broken...
It seems, that some folks who re-registered with v1.0.8 can send/receive again - without any further actions.
@Anna could you try it again? Re-registering should not be necessary.
And regarding v2groups:
Axolotl is capable of being added into new groups - not via invitation link, that's on the to-do list, but via direct addition from another user, with whom you had an encrypted conversation in Axolotl (key exchange is needed).
I hope, that answers your question, @kqlnut .
Cheers!
(11-30-2021, 03:47 PM)arno_nuehm Wrote: It seems, that some folks who re-registered with v1.0.8 can send/receive again - without any further actions.
After the hiccups described above everything is working fine again.
Thanks!
(11-30-2021, 03:47 PM)arno_nuehm Wrote: @Anna could you try it again? Re-registering should not be necessary.
Well, it seems to work erratically:
Sometimes I can send and receive messages and sometimes I cannot. When it starts working again, I receive all the missing messages at once.
The desktop app works, so it does not appear to be a Signal problem.
Here is v1.0.8-3 for Mobian user with Ozone deactivated - all letters except ü and V are back.
The screen is blurry and Axolotl is laggy as in the good old times though.
https://github.com/nuehm-arno/axolotl-mobian-package
Direct download
`wget https://github.com/nuehm-arno/axolotl-mo..._arm64.deb`
When the Electron/Ozone bug is fixed, there will be a new version. Fingers crossed.
Cheers
Could that be a internet connection thing? Sometimes, when my 4G is bad, I'm experiencing something similar...
(12-06-2021, 11:29 AM)arno_nuehm Wrote: Could that be a internet connection thing? Sometimes, when my 4G is bad, I'm experiencing something similar...
The problem is also there when the phone is connected via Wifi.
I think I'll try reinstalling it. I'm confused though:
The Axolotl download contains two packages: axolotl_1.0.8-3_arm64.deb and axolotl_1.0.8-2_arm64.deb
If I follow the instructions to
sudo apt install ./axolotl_1.0.8-2_arm64.deb
wouldn't I install the older version?
In v1.0.8-3 the Electron Ozone platform is disabled because it produces a nasty bug on Wayland systems like Mobian where letters cannot be typed.
If you are ok with a blurry screen and not so fast responding app, you can use v1.0.8-3.
And regarding that strange sending/receiving behaviour: I have no clue what could be the problem, but I'll ask the devs!
(12-06-2021, 12:48 PM)arno_nuehm Wrote: And regarding that strange sending/receiving behaviour: I have no clue what could be the problem, but I'll ask the devs!
It finally stopped working altogether, no reception of messages at all. So I purged Axolotl yesterday, removed all nanuc-directories etc, reinstalled & reregistered it and it worked -- for some hours. Now I don't receive any messages anymore and there's no connection to the desktop app (in the past I could sometimes see the messages I had sent from the app in axolotl).
That's new Sad Sorry to hear. Could you send me some logs
axolotl > log-file
via PM? That would be really helpful. Thank you - also for your patience and all the reports you have sent in the last weeks!
  Mobian-Kicksecure? 3460p 0 132 05-26-2024, 02:09 PM
Last Post: 3460p
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 3,282 05-17-2024, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 246 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,343 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 254 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,856 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,332 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,959 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 723 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,335 07-09-2023, 08:57 PM
Last Post: vusra
