Can't boot from SDCARD anymore...
Sad
First of all I'd like to say "I love my Pinebook Pro!"
Next, I'll state my problem.
I am unable to boot from sd-cards.
I can still boot from the main drive and I used to be able to boot from the sd-card but... I installed Armbian on the Pro (which is awesome) and I installed "firmware" through armbian-config. Maybe I should not have done that but I have had nothing but great experiences with Armbian on my other Pine64 boards so I didn't think anything bad would happen from doing this.
How can I restore the original boot preferences?
Thanks!
Bryan P.
I fixed the problem. I actually went back to using Manjaro. :-)
Yeah, I didn't care for Armbian much, too sterilized.  But it has a good reputation as something to try if you think there might be a hardware problem.
The boot order is preset in the hardware, you didn't change it by accident.  More likely your SD has a problem.  I haven't seen one last more than a couple years, less if it was a cheapie.  Sometimes you can stick it in a USB reader and copy your files off.  Then you might be able to reformat it and use it again, but you probably don't want to trust it much.
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,351 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,396 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,035 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 4,780 06-02-2023, 01:32 PM
  Tow Boot install help Paulie420 7 3,883 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 2,028 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 1,098 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,638 08-18-2022, 11:47 AM
Last Post: Bemo
  PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD Pino64 21 10,653 05-12-2022, 05:00 AM
Last Post: Pino64
  Broken eMMC boot annahellrothsparent 3 2,519 04-28-2022, 07:31 AM
