Did the pinephone 1.2a board undergo certifications?
Or was certification of the 1.2 boards "good enough"?
(10-10-2020, 12:00 PM)desca Wrote: Or was certification of the 1.2 boards "good enough"?
PCB v1.2a is identical to v1.2 with two components removed replaced. There was no need for the device to be re-certified again.
Just out of curiosity, do you know what makes a change significant enough to trigger recertification?
Any change to major components (ICs, transformers, antenna design) that leads to different functioning or specifications. There's a bit of info on this page for a company that helps clients certify (there is a section or two specifically mentioning licensed devices like mobile phones):
https://www.cetecom.com/en/certification...ification/
it doesn't get happy
it doesn't get sad
it just runs programs
Thank you. That makes sense to me that the FCC, at least, may be satisfied as long as you aren’t doing anything to the radio or maybe likely interference sources.
  my pinephone melted norayr 6 1,019 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,142 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 761 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 404 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,945 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,788 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,467 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,065 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,314 08-23-2023, 03:25 AM
Last Post: Kali
  Pine phone main board part Generaltuxenburg 1 1,123 07-31-2023, 07:50 PM
