Mobian builds
A while back a kind gentleman posted the build recipes for Mobian.
For anyone else curious, it's here.
https://gitlab.com/rrico542/mobian-x-recipes/
I plan on doing a few builds sometime this month and after a bit of testing probably customize my own build.
I know a lot of people would like to try out plasma with Mobian so let me know, and once I build the image I would be happy to provide it for others.
Please note the base recipes are here: https://gitlab.com/mobian1/mobian-recipes
Since the repo you mention hasn't been updated in some time, you might want to rebase on mobian-recipes first.
(09-16-2020, 02:32 AM)a-wai Wrote: Please note the base recipes are here: https://gitlab.com/mobian1/mobian-recipes
Thank you, good to know.
(09-16-2020, 01:39 AM)SwordfishII Wrote: A while back a kind gentleman posted the build recipes for Mobian.
I would love Plasma on Mobian. I use Mobian because I feel like it is the best mobile OS out there for the PinePhone right now. But at the same time there are a fair amount of things I don't like about Phosh but it also happens to be the most stable for Mobian so I use it.
No promises. But i figured if I get something usable others might be interested too.
I've just been trying out plasma on arch on the PineTab (pinephone should be basically the same) after following the (fairly quick and dirty)  steps another user posted here https://forum.pine64.org/showthread.php?...8#pid77948
You should be able to do something similar on mobian by using apt instead of pacman and checking the names of the packages against what Debian provides, It's a fairly minimal effort for a tryout.
Id love plasma mobian! But i have heard that getting the modem working and integrated is a lot more complicated
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 23 2,346 Yesterday, 04:17 AM
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,928 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 146 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,050 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,857 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,020 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,930 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 643 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,066 06-19-2023, 03:02 PM
Last Post: vusra
