11-23-2020, 05:24 PM
Thanks Megi. Right now I start to download it.
UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant)
11-23-2020, 05:34 PM
WOW, that's a great news!!! I'm going to download it right now!! Thanks!
11-28-2020, 07:42 PM
Hello I made it to this step in the instructions
sudo echo ", +" | sfdisk -n -N 2 /dev/sdb2 sfdisk: cannot open /dev/sdb2: Permission denied And when I try the next command I get sudo echo ", +" | sfdisk -N 2 /dev/sdb2 sfdisk: cannot open /dev/sdb2: Permission denied Suggestions? Thanks
11-29-2020, 04:25 AM
I can't get sound playback in UBports. I can get sound in Manjaro and Mobian once I change setting from Analog to speaker. Any idea as how to do the same in UBPorts?
(11-28-2020, 07:42 PM)K_Research Wrote: Hello I made it to this step in the instructionsWhere did that command come from? The elevated permissions from sudo only apply as far as the pipe '|' so sfdisk runs as the normal user, hence the permission denied. If you remove the first sudo, and insert one between the pipe and sfdisk, you'll probably get what was intended. As always when using sudo, make sure you know exactly what it's doing before running it! UPDATE: It looks like you were trying to follow https://xnux.eu/log/#toc-resizing-the-pa...-the-image but using sudo, and changing the block device. I think you should be using /dev/sdb not /dev/sdb2 - the whole device not the second partition on that device.
11-29-2020, 07:45 AM
(11-23-2020, 03:36 PM)megous Wrote: New version is now available. https://xnux.eu/p-boot-demo/ Thanks a lot! I followed the steps to resize the partition and noticed that the last two steps only work in reverse order, i.e. Code: df -h
11-30-2020, 07:14 PM
Hey guys, I am trying to resize the partition to the max of the SDcard filesystem from the Pinephone, but for some reasons I can't find the command btrfs, I've tried with apt but it doesn't find the package. Which is really weird, because it should be a base command of Linux. I am probably missing something, any idea?
Pinephone Braveheart
Pinephone Manjaro CE 3/32Gb Pinephone Mobian CE 3/32Gb Pinephone Pro Explorer Edition
12-01-2020, 10:03 AM
(11-30-2020, 07:14 PM)deedend Wrote: Hey guys, I am trying to resize the partition to the max of the SDcard filesystem from the Pinephone, but for some reasons I can't find the command btrfs, I've tried with apt but it doesn't find the package. Which is really weird, because it should be a base command of Linux. I am probably missing something, any idea?Did you try searching for the correct package name? Code: apt-cache search btrfs (12-01-2020, 10:03 AM)wibble Wrote: Did you try searching for the correct package name? Shame on me, I searched for btrfs-filesystem (I saw that in the 8 man page of the debian btrfs page, and I assumed that was it). Now I have managed to fix the issue, thanks!
12-02-2020, 09:27 AM
(11-29-2020, 04:25 AM)neil_swann80 Wrote: I can't get sound playback in UBports. I can get sound in Manjaro and Mobian once I change setting from Analog to speaker. Any idea as how to do the same in UBPorts?I tried porting the UCM profile in UBports to the latest kernel (without testing), but maybe it's somehow still not working. You can either debug the UCM profile, or wait until ubports moves from Linux 5.6 to Linux 5.10.
my website: https://xnux.eu
eSIM on PinePhone | just_a_q | 3 | 2,684 |
05-11-2024, 03:41 PM Last Post: bam |
Pinephone boot. | Richy_T | 4 | 181 |
05-06-2024, 08:32 AM Last Post: Richy_T |
PinePhone - boot from microSD | laserpyramid | 9 | 932 |
05-03-2024, 10:09 AM Last Post: laserpyramid |
pinephone virtual keyboard | aular | 4 | 463 |
04-10-2024, 03:45 PM Last Post: aular |
PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging | dorkydev | 1 | 314 |
04-02-2024, 11:50 AM Last Post: Kevin Kofler |
Are you using the Pinephone as your daily driver? | jro | 157 | 111,486 |
02-18-2024, 11:33 PM Last Post: aular |
2020 PinePhone Manjaro CE EU for sale, name your price | astrojuanlu | 7 | 1,973 |
02-14-2024, 04:51 PM Last Post: astrojuanlu |
pinephone is not bootble for the box. | ijij | 1 | 701 |
01-19-2024, 01:29 PM Last Post: fxc |
Multiple issues with the Pinephone | MTXP | 12 | 2,631 |
12-28-2023, 07:55 AM Last Post: MTXP |
pinephone repair shop | shengchieh | 0 | 567 |
12-26-2023, 02:42 PM Last Post: shengchieh |
