What do you use for voice chat on Mobian?
My phones motherboard just stopped working so I am now forced to use the PP as a daily driver. It's been alright so far but the microphone on the phone is super staticy and it won't work with my bluetooth headset. I can listen to music but can't talk over the phone. I can't get discord on the phone and Axolotl doesn't do phone calls so what other options are there?
telegram(-desktop) works pretty reliably for me with voice calls. Haven't bothered to sort the default linux/pinephone camera bits to try get video calls working but pretty sure it can be done.
(07-25-2021, 03:37 AM)dukla2000 Wrote: telegram(-desktop) works pretty reliably for me with voice calls. Haven't bothered to sort the default linux/pinephone camera bits to try get video calls working but pretty sure it can be done.
I swear I tried telegram at least 5 times and never got past the screen asking for my number. It got me past that point just now launching it from the command line. Do you have to launch it from the command line as well?
Also, it got to the point where it said it sent me a text with a code but 5 minutes later I haven't gotten it. Is did this happened to you?
The registration is variable between slow and extremely slow. 10 minutes is quite possible. Just keep trying/waiting.
For me it starts fine from the (desktop) icon.
I eventually never got the text on my phone so I set it up on my tablet and got the text from there then just used the QR scanner for my phone. Thanks for the help though, the quality is much clearer than regular phone calls.
I think it did send a text to my pinephone, but it is an mms. I can see that long string of letters and numbers when I go to the terminal, but it's not decipherable as a code....
I never got mine, even as MMS, but I set it up on a different device and then used that device to set up my PinePhone. After you have a device setup you can just scan the QR code I think.
I installed it on my GPD MicroPC. There was a QR code that I tried to use the Pinephone's Megapixel to scan.  a blue outline appeared around the QR image.  I pressed the button to take the picture. Nothing happened except that I have a picture of the QR code......Sad
(07-25-2021, 09:34 AM)ragreenburg Wrote: I swear I tried telegram at least 5 times and never got past the screen asking for my number. It got me past that point just now launching it from the command line. Do you have to launch it from the command line as well?
I believe you are supposed to scan it the other way around if I remember correctly. I pulled up the QR code on my phone and scanned it with my tablet and that worked. Or I could be misremembering.
(07-25-2021, 06:22 PM)dukla2000 Wrote: The registration is variable between slow and extremely slow. 10 minutes is quite possible. Just keep trying/waiting.
Ah, so that assumes you have a camera on your tablet then?  I don't have one on the MicroPC, but I do have one on the P2Max.  It didn't work either. I did try to scan with my phone again, and this time there was an option to go to the URL. I chose it (on the megapixel screen) but nothing happened. My version of the Telegram-desktop doesn't have Setting - Device - ....so I think it's just an endless loop of no account.
  Mobian-Kicksecure? 3460p 0 115 05-26-2024, 02:09 PM
Last Post: 3460p
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 3,256 05-17-2024, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 235 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,323 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 248 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,322 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,959 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 721 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,329 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,993 07-09-2023, 01:37 AM
Last Post: vusra
