Installing chromium browser?
(01-25-2021, 11:30 AM)Zebulon Walton Wrote: Aside from not working with X forwarding, another issue with the flatpack edition of Chromium seems to be that "scale-to-fit" cannot be used to scale it to the screen since there is no APP-ID associated with it. Items in the browser can be resized using keyboard commands, which helps, but there appears to be no way to scale the browser window itself. So for example to manipulate settings it is necessary to keep switching between portait and landscape modes to get at everything.
This was what I did.
sudo apt install flatpak
flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
flatpak search Chromium
It gave me 5 versions to choose from, two of them degoogled. I installed two of them. The names identified in the search were the app ID I used for scaling.
flatpak install Chromium
scale-to-fit Chromium on
Then I installed an extension from the Chrome store called Mobile View to make it spoof to mobile. It's much faster then Firefox ESR, loads faster, smoother scrolling. None of the versions I tried will save my passwords. The keyboard has to be throttled up and down with the button and the @ symbol on the touch keyboard for some reason doesn't work. There was an update today to Chromium on the Pinephone today that might have fixed it. I have to try again. The deGoogled one is desktop use only when I am docked. No extensions.
Then I installed an extension from the Chrome store called Mobile View to make it spoof to mobile. It's much faster then Firefox ESR, loads faster, smoother scrolling. None of the versions I tried will save my passwords. The keyboard has to be throttled up and down with the button and the @ symbol on the touch keyboard for some reason doesn't work. There was an update today to Chromium on the Pinephone today that might have foxed it. I have to try again. The deGoogled one is desktop use only when I am docked. No extensions.
Late to the party here but you can use the ungoogled version of Chromium (May work with standard chromium too) and run it over Wayland via
flatpak run com.github.Eloston.UngoogledChromium --enable-features=UseOzonePlatform --ozone-platform=wayland
Thanks for the tip. I enabled it but I don't really notice any difference in performance or anything. It might have already been enabled. Here is a tip for those who try it. Open the browser before you enter the terminal command to enable Wayland or you will get an error code and the browser will open but without Wayland enabled.
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 1,693 01-07-2023, 09:36 AM
Last Post: dcarvil
  Epiphany browser broken after webkit packages upgrade user641 0 879 04-15-2022, 05:20 AM
Last Post: user641
  Firefox browser tweaks biketool 4 3,214 03-11-2022, 04:14 AM
  Browser cog - Problems on Mobian arno_nuehm 5 4,103 02-10-2022, 03:27 PM
Last Post: pothos
  ARM Microsoft Teams-problems installing eaglebeckley 15 14,825 01-14-2022, 01:59 AM
Last Post: Tazdevl
  nordvpn and web browser daniel 11 10,367 10-03-2021, 06:23 PM
Last Post: fluffylimey
  Installing Mobian --> "Resizing file system" forever Anna 13 13,322 09-09-2021, 04:26 AM
Last Post: spaetz
  Can't type @ from keyboard in chromium flatpak motox6 1 2,077 06-17-2021, 07:18 PM
Last Post: pjsf
  Installing and tweaking Chromium on Mobian and Arch C0ffeeFreak 19 19,750 03-11-2021, 09:24 AM
Last Post: C0ffeeFreak
  "Low Disk Space on Filesystem root" after installing Axolotl and Podcasts Anna 11 9,036 03-05-2021, 02:33 AM
Last Post: Anna
