nordvpn and web browser
I gave it a try installing nordvpn on pinephone.
The installation went smoothly.
I connected to VPN and said was connected to another country.
I whitelisted port 22 to ssh
However, when I tried to use Firefox there is no connexion
I wonder if anyone has tried and can help
thanks
(02-15-2021, 11:12 PM)daniel Wrote: I gave it a try installing nordvpn on pinephone.
thanks
I am the only one using VPN on the pinephone? cool... well if it just worked...
Only one using nordvpn maybe - other VPNs are available:
https://wiki.mobian-project.org/doku.php...tonvpn-gui
https://wiki.mobian-project.org/doku.php...o:security
https://wiki.mobian-project.org/doku.php...orking#vpn
Don't run the VPN on your phone just run it on your browser. Just add the extension. I am doing the same thing only in the Chromium browser. It works pretty well.
(02-17-2021, 07:04 PM)wibble Wrote: Only one using nordvpn maybe - other VPNs are available:
So, are you running a vpn and browsing without a problem?
Just in case someone sees anything that could help, this is the connection status. It looks it connects, but then Firefox do not find any page.
I am connecting from US to Spain:
mobian@mobian:~$ nordvpn status
Status: Connected
Current server: es185.nordvpn.com
Country: Spain
City: Madrid
Your new IP: 195.206.107.9
Current technology: OpenVPN
Current protocol: UDP
Transfer: 4.91 KiB received, 12.41 KiB sent
Uptime: 3 minutes 37 seconds
I've not tried them on the PinePhone - just trusting those that posted instructions. I've never had much trouble with OpenVPN or Wireguard on other linux boxes, but that may reflect time spend messing with low level stuff on networks in general. Have you checked the basics like DNS are working?
thanks
I had the same problem. When I checked the status, it looked good, but trying to load web pages didn't work until I disconnected from the VPN.
This is via Wi-Fi, without a SIM card inserted.
In terminal, can you try pinging the web?
ping 8.8.8.8
and then ping google
ping www.google.com
To rule out DNS resolver issues
I've ran private internet access vpn with wireguard tunneling on mobian just fine (all of the phones network traffic was behind it, browsing worked just fine). So this should work without any hiccups. If it's just webpages though, sounds like DNS
I found NordVPN's instructions for setting up OpenVPN here:
https://support.nordvpn.com/Connectivity...rminal.htm
I followed those instructions and left the terminal running while I opened a browser to check that my IP address matched the server I chose. It worked! Just make sure you look up your info on their dashboard, since the username and password it wants aren't the ones you chose when you created the NordVPN account.
thanks
I got the CLI for nordvpn running on Mobian.
It needs the DNS servers set to the nordvpn nameservers and ipv6 set to off.
To set ipv6 to off I followed these instructions: https://support.nordvpn.com/Connectivity...-Linux.htm
I updated the DNS nameservers using the information here:https://www.tecmint.com/set-permanent-dns-nameservers-in-ubuntu-debian/
Using the information from here: https://support.nordvpn.com/Connectivity...-Linux.htm
Hope this helps
  Epiphany browser broken after webkit packages upgrade user641 0 837 04-15-2022, 05:20 AM
Last Post: user641
  Firefox browser tweaks biketool 4 3,059 03-11-2022, 04:14 AM
  Browser cog - Problems on Mobian arno_nuehm 5 3,905 02-10-2022, 03:27 PM
Last Post: pothos
  Installing chromium browser? Zebulon Walton 12 13,476 02-09-2021, 12:33 PM
Last Post: C0ffeeFreak
