[split] U-Boot with NVMe support, keyboard & display working
#61
@simonsouth more good news. You also resolved problem with distortions on the screen after kexec Smile
I have tested today and it works ok. And this problem is present in the kernel for like last 3 years.
Will this patch be accepted into the mainline ?
P.S. I have tested kexec with all the display stuff compiled into the kernel (rockchip-drm, panfrost, analogix-dp etc.). It might make a difference but I don't really think so.
(10-02-2020, 05:05 AM)as400 Wrote: @simonsouth more good news. You also resolved problem with distortions on the screen after kexec Smile
Wonderful! I'm really happy to hear this.
(10-02-2020, 05:05 AM)as400 Wrote: Will this patch be accepted into the mainline ?
I believe so. It's in linux-next right now.
Nice work! It's a pleasure reading and learning from you all...
Sent from my PH-1 using Tapatalk
New version of u-boot - 2020.10.
Kernel patch is still needed. I think the patch was accepted into mainline 5.10.
https://gitlab.com/as400l/pbp-uboot-disp...27.10.2020
Good news - @simonsouth patch has made it into linux-5.9.2 Smile
So if your distro offers kernel 5.9.2 you can use this u-boot probably without the problems with display not initializing properly.
(10-30-2020, 01:18 AM)as400 Wrote: Good news - @simonsouth patch has made it into linux-5.9.2 Smile
Thank you and others for your work in the community. I'm very new to Linux and reading through this thread makes me interested to try out. I like the idea of choosing what device to boot from. My pinebook is running manjaro 20.10 and I believe the uboot from factory resides in the Emmc and would like to replace the current one with that in this thread. Though honestly I don't know where to start, would someone be kind enough to explain how to implement this?
@FeMike, First, try learning more about your existing system. Dealing with U-Boot is very experimental, and has the potential to soft-brick your Pinebook Pro.
If you are really new to Linux, you need to check the kernel level with the following command. Then you can see if your kernel is at 5.9.2 or higher.
uname -r
I've been working with Unix for more than 25 years, and still get bit by odd things. It's never fun to spend hours trying to recover from some bonehead mistake, That of course you did not know was a bonehead mistake, until after.
Arwen Evenstar
Princess of Rivendale
Nice, yeah it's running 5.9.6.1
Edit: So I just went for it and just did it. I learned a few things and it seemed to work though I may not fully understand how to choose which device to boot from. I press control+c for boot menu but it continues on to boot from sd card. I'm sure I'm missing something but when I get back from work I'll keep trying. Thank you.
(11-21-2020, 04:49 PM)FeMike Wrote: Nice, yeah it's running 5.9.6.1
I have the same problem, but oddly enough if I hit the arrow keys instead of ctrl+c on boot, it works every time.
Thank you much!
  upgrading u-boot--what version? where to get it? bsammon 11 541 05-22-2024, 09:33 AM
  uboot wont boot to SD card after upgrade jbradley419 7 1,146 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 401 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,546 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 875 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 719 11-22-2023, 11:47 AM
Last Post: fxc
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 859 09-27-2023, 08:53 PM
Last Post: pinemouth
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,373 09-19-2023, 08:48 AM
Last Post: dachalife
  Dead Pinebook Pro Keyboard Keys calinb 2 1,191 09-02-2023, 12:31 PM
Last Post: calinb
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 2,130 08-03-2023, 03:30 PM
