Hi sigmaris,
The builds on Azure seem to have expired - would it be possible for a new image to be created with the SPI installer and compressed image support?
Additionally, is it possible to increase u-boot's debug level? It might help me solve an unrelated issue.
used rockpro64 u-boot v2020.01-ci but it does not detect storage on usb 3.0. It does detect the JMS578 on usb 2.0 however, but so does literally every other uboot version I've ever flashed - aka this is nothing special.
I want the usb 3.0 port to work for 2 reasons:
1. it's faster transfer speed
2. it actually manages to power a spinning drive as opposed to usb2.0 which screws up and you have to unplug and replug to get a successful spin-up. No, it's not the damn power supply, I can do that with a 12V 1.5A lying around just as well as the 12V 3.5A. It's not lack of power, it's whatever the board instructs the controller to do, which is to cycle power repeatedly for some weird reason.
Here it is when I unplug and plug back in on usb 2.0:
Device NOT ready
Request Sense returned 02 04 01
2 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Device 0: Vendor: JMicron Rev: 3102 Prod: Generic
Type: Hard Disk
Capacity: not available
... is now current device
Device NOT ready
Type: Hard Disk
EHCI timed out on TD - token=0x80008d80
On U-Boot TPL 2020.10-07965-g0ce9b07852 (Oct 12 2020 - 21:45:42), if you issue "usb reset" U-boot will freeze. It does not respond to anything, the only option is to power cycle the sbc.
10-29-2020, 07:08 AM
(This post was last modified: 10-29-2020, 07:13 AM by diskers.)
How to get ride of this problem?
Device 0: unknown device
failed to find ep-gpios property
I have the appropriate PCI-Express card (pcie to nvme) but get this error
Any help is welcome
Thanks in advance
