KDE Neon Pinebook remix edition RC image
#51
(11-09-2018, 05:10 AM)bvbfan Wrote: In link has pinebook-remix-nonfree - so that's Open Source Notebook which is non-free even non-open source or i should use Arch Linux with kernel 4.19 ?
I think the image means it uses BSP + blobs
#52
So kernel + blobs is OK, hope it's only that.
#53
Yes here non-free means Mali blobs and kernel is BSP kernel. Not non-free in the sense of Microsoft Windows Wink
#54
Loving this KDE user edition, thank you so much! I'm curious if you have any details on why HDMI doesn't work? Is this a fixable issue? Everything else has been great so far!
#55
(11-15-2018, 02:17 PM)rpm Wrote: Loving this KDE user edition, thank you so much! I'm curious if you have any details on why HDMI doesn't work? Is this a fixable issue? Everything else has been great so far!
The problem is in how BSP works - once Neon switches over to mainline (hopefully soon), output via HDMI will no longer be an issue.
#56
Mine is here, also. It's new 1080p edition, can we expect kernel 4.19 image?
#57
I"ve install and upgrade, so everything works great, except hardware acceleration. So probably it should be fixed when NEON gets 4.19?
toni@toni-pc:~$ glxinfo | grep -i opengl
MESA-LOADER: failed to retrieve device information
libGL error: unable to load driver: sunxi_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: sunxi
OpenGL vendor string: VMware, Inc.
OpenGL renderer string: llvmpipe (LLVM 6.0, 128 bits)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 18.0.5
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 18.0.5
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 18.0.5
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
#58
It seems VDPAU is ok, vdpauinfo says ok, but not in the browser.
#59
Hello! I wonder whether it's normal that windows in KDE Neon are sometimes rendered with transparent 1-pixel thick horizontal line-holes.
One notable example is Konsole (which I use a lot), where newlines often result in transparent lines through the window. I assume this is a bug with partial window update (KWin?), because it seems that sometimes a full redraw happens and lines disappear.
#60
Am I right that GPU on BSP kernel doesn't work, and there is no way to make it work?
  DietPi OS for Pinebook MichaIng 3 5,580 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 62,832 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 1,017 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 800 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,990 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,313 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,999 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,344 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,876 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,865 12-25-2020, 04:40 PM
Last Post: ford442
