Error formatting Memory Card
I am using a 8GB memory card and the PhoenixCard software as suggested and I am trying to use the most recent build of Lollipop that was posted and I am getting an error.  Any help or suggestions.  I am trying to boot up my board to test it out since I received it yesterday in a banged up box.
(03-16-2016, 04:21 PM)Astondb5 Wrote: I am using a 8GB memory card and the PhoenixCard software as suggested and I am trying to use the most recent build of Lollipop that was posted and I am getting an error.  Any help or suggestions.  I am trying to boot up my board to test it out since I received it yesterday in a banged up box.
If you have additional PC or notebook, you can try on different PC and check whether able to burn successfully.
You can also try fully formatting the card first before burning the OS.
(https://www.sdcard.org/downloads/formatter_4/)
I resolved it by formatting the card with the Linux image and then I went back and reformatted with the Android image and it successfully burned. About to try and boot it up now. Smile
(03-16-2016, 10:20 PM)Astondb5 Wrote: I resolved it by formatting the card with the Linux image and then I went back and reformatted with the Android image and it successfully burned.  About to try and boot it up now. Smile
Kind of interesting method, learn a new trick today :-)
Did you use PhoenixCard to burn the Linux image?
No I used the Win32diskimager that is suggested with the Linux image
(03-17-2016, 07:12 AM)Astondb5 Wrote: No I used the Win32diskimager that is suggested with the Linux image
Ok, thanks.
No problem, I was able to boot into the Android desktop last night successfully. Now just to solve my overscan issues I'm having.
(03-17-2016, 07:26 AM)Astondb5 Wrote: No problem, I was able to boot into the Android desktop last night successfully.  Now just to solve my overscan issues I'm having.
No able to abjust over scan issue have been reported but not yet fixed. This cause by new release HDMI driver and needs sometimes to resolved, will not be resolved on coming release but should be resolved on release after that.
  PBP Debian 11 GRUB install error zlth 2 4,888 11-18-2022, 07:42 AM
Last Post: zlth
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 3,281 05-23-2022, 08:49 AM
Last Post: 98cwitr
  How to boot from SD card on pinebook pro linux123 3 10,334 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,084 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,158 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,282 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 301,213 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 18,773 03-20-2018, 11:14 AM
Last Post: Malmgren
  Upgrading Memory on PINE64 + 2GB Osh818 2 7,694 04-24-2017, 10:12 PM
Last Post: Osh818
  corrupt microsd card after reboot maxpayne 6 16,038 02-08-2017, 05:42 PM
Last Post: maxpayne
