Case Mod Opening for Serial Console Slider Switch
Greetings,
I've been working on a Pinebook case mod which will safely expose the serial console slider switch on the main board without dismantling the Pinebook every time;  that was getting old fast-- ten tiny little screws ( its a miracle I have lost none of them yet ) !
The pic above is the slider switch;  look to the upper left of the pic and you'll see the pencil marks for the proposed dremel styrene work. The switch is in from the side 1.1 - 1.7 cm  and down from the back 8.1 - 8.2 cm.
I chose a 1.0mm carbonide cutting wheel for the dremel tool; do this from the underneath side cause it makes one dandy mess, but it cleans up nicely with a sharp modeling knife and a nail file.  Tip:  practice on another piece of styrene first ;  dremels take some getting used to.
This is the case opening after cleanup;  there is still ample protection, things will stay out of there, but the switch may be accessed easily.
Final pic is my high intensity 9 LED flashlight illuminating the slider switch inside the Pinebook case.  I use a simple slider switch access tool (toothpic) and voilà  !
Shy
Nice!
  UART switch Pinebook 11.6" irongarment 3 3,528 01-03-2022, 03:28 AM
Last Post: kqlnut
  Case crack ImmortanJoe 18 25,537 10-17-2020, 01:55 AM
Last Post: Mick
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 23,228 07-02-2020, 06:33 PM
  Pinebook serial info maldus 1 3,087 11-20-2018, 12:00 AM
Exclamation Pinebook uart(0) Slider Switch Enable -- Disables left-hand USB Port MarkHaysHarris777 1 2,712 08-27-2017, 10:30 AM
Last Post: MarkHaysHarris777
  Switch inside the case hene 3 4,879 08-13-2017, 08:27 AM
Last Post: xalius
  Does the case take paint? combs 4 5,277 08-08-2017, 03:06 PM
Last Post: combs
Information Serial port pfeerick 2 5,111 07-05-2017, 01:02 AM
  What is the little switch for? AndyK 4 5,822 06-20-2017, 10:33 AM
Last Post: AndyK
