Pinebook serial info
Hello everyone,
I need help understanding the possibility of using the audio jack a serial connection. Specifically I want to know:
   1. How to enable this serial port
   2. What I can do with it
I've found at least 3 different ways to activate it: the guide pointed by the store (http://files.pine64.org/doc/pinebook/gui..._Guide.pdf), the pinebook_enable_uart.sh script (https://github.com/ayufan-pine64/linux-b...le_uart.sh) and toggling the switch inside the case.
Only the switch worked for me, and I was able to see the Pinebook boot logs and access a login shell. I was also able to open /dev/ttyS0 from the Pinebook and send characters to the other end, but I wasn't seeing anything I wrote from my other laptop (is it supposed to work like this? Only a login shell, not controllable thorugh other means?).
Now, if I had to open the case every time to switch back, I'm just going to keep the audio jack. I've eard on the Discord channel however that the soft switch should in fact work. Is that the case? Which method should I use then? None of what I've tried seems to work.
(11-18-2018, 09:52 AM)maldus Wrote: Hello everyone,
I will check with hardware engineer on whether any change on the software method.
  pinebook 1080p power/barrel connector/cable cel 0 545 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,375 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,224 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,632 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,318 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,603 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,613 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,783 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,674 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,888 07-02-2020, 06:33 PM
