10-26-2016, 02:50 AM
Why you would release build 5.1.1? When you said in few weeks back that Android 6.0 is on the way!
ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem)
10-26-2016, 07:22 AM
good work
Android 5.1.1 Image Release 20161019 i have to use static ip to get this to work on GbE lan i got <10mbit on lan thx for your hard word
10-26-2016, 12:27 PM
But we can also test it on Android 6.0. Anyway do you have ETA, when you will release Android 6.0 for us?
10-27-2016, 07:11 AM
10-27-2016, 08:06 AM
Here are all the links to the test imgs for your convenience :
8GB http://files.pine64.org/os/android/andro...8GB.img.gz 16GB http://files.pine64.org/os/android/andro...6GB.img.gz 32GB http://files.pine64.org/os/android/andro...2GB.img.gz 64GB http://files.pine64.org/os/android/andro...4GB.img.gz Phoenix Card Img: http://files.pine64.org/os/android/andro...ard.img.gz
10-27-2016, 10:40 AM
i installed Android 5.1.1 Release 20161019 yesterday.
Good News is that i could connect the pine64 to gigabit ethernet port directly and it worked. Bad News is that my network bandwidth in pine64 did not go beyond 150kbps. Everything was so slow. Installing app via Playstore took for ever that i had to go back to the previous Android build.
10-28-2016, 12:22 PM
Thanks for the links...
I checked on the wiki, not on the pine64.org pages ;-)
When your testing new Android 5.1.1 Image release 20161019 , but i find the bug from Android 5.1.1 Image Release 20160711
can't setting network Static Network is broken , only can work automatically connect network 2. youtube video is not 1080p , maximum is only can show 720p , just the hdmi can set output to 1080p or 720p , the actual resolution is 1280X720 this maybe you know , but i long time not come to here If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP ) 2. Use Pine64 Running Official Android 6 for Media player 3. Use Pine64 Running Volumio Digital Audio Player |
