So my Pine64 2g board of course arrived without the play box I ordered with my pledge. Been able to play around with it just sitting on the desk, everything works good. Since I have no idea IF or WHEN the playbox will arrive, I've been digging around the house for something to use as a sort of case enclosure. Have found a couple of unique plastic boxes that would work, but the ribbon cables for the TP won't be long enough. Can of course just use the hdmi, but if I could find some ribbon cable extensions for the TP I'd be able to hook that up as well.
Anybody know where I could find ribbon cable extensions? just need to extend them 2 or 3 inches....
(06-26-2016, 07:07 PM)tllim Wrote: (06-26-2016, 06:08 AM)Severian Wrote: So my Pine64 2g board of course arrived without the play box I ordered with my pledge. Been able to play around with it just sitting on the desk, everything works good. Since I have no idea IF or WHEN the playbox will arrive, I've been digging around the house for something to use as a sort of case enclosure. Have found a couple of unique plastic boxes that would work, but the ribbon cables for the TP won't be long enough. Can of course just use the hdmi, but if I could find some ribbon cable extensions for the TP I'd be able to hook that up as well.
We plan to provided another longer LCD extension cable when playbox shipped on late July.
Tllim- are you referring to an extension cable for TP? I really hope so.
Matt
My email to Pine eventually got through the queue and a replacement cable was promised. By that point I'd already ordered the cable from Farnell anyway and am happy to report that it was a perfect fit. I was also able to get the screen working after downloading the latest Android build. So far, so good!
What about a TP extension cable? That's what I'd like most.
Matt
IMHO, both cables need extensions.
Matt
