Mobian + phosh firefox ublock and other overlays display bugs
hi!
i've been trying my pinephone for a while now, and i've noticed that in firefox it's almost impossible to use overlay menu's
example:
-you open ublock (default installed) and the overlay menu just flickers or doesn't size right
-if you use the toolbar menu with alt and open one of submenus  like file or tools, you get the same flicker/non display
Is there a solution to this?
i really would like to use firefox with tight ublock measures but then i need to use the menu.
(01-24-2023, 11:43 AM)tuxcall Wrote: Is there a solution to this?
No solution I know of at least Sad - Interesting: I have this annoying problem since a few months, but NOT from the beginning (with Mobian & Firefox on my PinePhone), so it has to do with an former update... I just don't know which one. Firefox? Graphics driver? Phosh...?
(At the same time context menus in Firefox got buggy for me, sometimes I can select the entry I want, sometimes it scrolls to hell and back and doesn't let me choose...)
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
I have the same issue on pmOS with both Phosh and Sxmo, so at least it's not a Phosh issue, nor a Mobian one.
PinePhone Beta Edition 3GB RAM - custom firmware v.0.7.4 - ADSP v.30.007 - postmarketOS edge - sxmo
(01-24-2023, 11:43 AM)tuxcall Wrote: hi!
example:
I also have this issue, but have a stupid work around to offer.
I set my display to 150% or 125% in phone settings and I open the menu holding the phone vertically. This exhibits the bug, but then I turn the phone sideways and it shows the controls for the NoScript plugin well enough to modify settings.
On a side note you may want to look at no script. It gives per domain control of scripting. Thus you can allow websiteyoulike.com to script but creepytrackersnoop.net can suffer without their scripts to monetize you. Other blocker add-ons do similar with curated blacklists, but noscript lets you do it by hand so it is very strict. You would be amazed how few of the domains running scripts on your computer at each website you visit require scripting for the page to work. Often sites can have ten or so domains running scripts under them, but only require the primary website's domain or the primary plus a "cdn" to function. It has a tendency to clip out advertisements and other unwanted interactions. The add-on can also catch some of the more shady operations like cross site scripting and alert you.
  Mobian-Kicksecure? 3460p 0 185 05-26-2024, 02:09 PM
Last Post: 3460p
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 27 3,443 05-17-2024, 07:58 AM
Last Post: treebeard
  atinout binaries for mobian/debian? NeutralGrey 2 281 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,466 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 287 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,397 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Auto start application on Phosh login Zebulon Walton 8 3,779 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  What actions needed to keep on mobian testing user641 3 1,973 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 735 09-01-2023, 11:29 AM
Last Post: Mahgue
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 651 08-30-2023, 03:23 PM
Last Post: jojuma
