03-08-2022, 01:43 PM
(03-07-2022, 04:59 PM)dieselnutjob Wrote: Have I understood correctly that with your 4.19 the MIPI-DSI LCD panel will work, but with your 5.10 it won't ?
I understand why everyone says just to use mainline, but for an LCD panel it doesn't yet work (though I think that they are getting near).
it is just a rk 4.19 nothing realy special maybey a few versions higher as on your original tablet firmware
you know it all comes to the dts i disabled dsi-mipi in my dts because i dont use it .
for now you could be a little more lucky with a downstream kernel like this kernel for your tablet to get display output .
just look what changed in the dts files of your dtb with recent dts files also dts files change a litte with build verions 4.19.219 has little changes from example .193
thought mipi0 got video0 but you will find out
the 5.10 you just forget
do you have a dtb or dts of your tablet i can throw it in a android 12 build
