sd card wear vs partition size
Hi folks!
Let's say I have a 32GB sd card with a partition smaller than full size, eg. 1GB. Will it wear out faster than with a full size partition or will the wear laveling use the unallocated space anyway?
(11-07-2021, 10:02 AM)guenther Wrote: Hi folks!
Wear leveling on SD cards in done by the SD card hardware. The SD card hardware does not know anything about partitioning. So, wear leveling on your 1GB partition spreads over your whole 32 GB card.
This is not true for raw flashes where the filesystem is doing wear leveling.
@Der Geist der Maschine Thank you for the quick reply!
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 370 04-11-2024, 03:10 PM
  Cannot pay with credit card: VISA: "card was declined.". MasterCard: "Bad Gateway". dreieck 4 2,842 04-15-2023, 04:21 PM
Last Post: pinkkat
  Credit card rejected by the bank farleymartinez 4 2,541 12-14-2022, 12:03 PM
Last Post: fxc
  Are you OK with the size of the PinePhone? guenther 14 8,661 12-16-2021, 12:12 AM
Last Post: zetabeta
  SD card / Sim slot dilemma zez 3 4,382 12-14-2020, 10:08 AM
Last Post: zez
  sd card limits cmcanulty 2 3,865 06-19-2019, 05:43 AM
Last Post: cmcanulty
  Purchasing with credit card blindson76 0 2,751 06-08-2018, 12:25 PM
Last Post: blindson76
