printer
@awai, is it possible to integrate System-config-printer in the settings ?
I'll have to check if it works fine first, but it is possible, yes
(05-28-2020, 09:24 AM)a-wai Wrote: I'll have to check if it works fine first, but it is possible, yes
System-config-printer works after install but to use the local cups server, you need :
- install cups-client
- mkdir /etc/cups
- create the file "client.conf" and insert the following line : ServerName 'the name of your server without the '
- if you don't have a local dns then insert the name of your server + ip in your file etc/hosts
PS : I add these infos because System-config-printer is no longer present in the wiki
