Connect i2c under Remix OS
Hi everyone. Could you tell me how can I connect i2c device to pine64 under Remix OS. I plugged pins to pi-2 connector of pine64
Vin -> Pin1 (Vdd)
GND -> Pin6 (Gnd)
SDA -> Pin3 (SDA)
SCL -> Pin5 (SCL)
Wrote some app on Android to detect I2C device, it shows no devices, moreover my i2c device has led which is on when the vdd is plugged, i see that led is off.
I've attached the picture where you can see how my device plugged and its state (led is off)
link
(05-07-2016, 06:03 AM)IlyaM Wrote: Wrote some app on Android to detect I2C device, it shows no devices,
As expected, Allwinner forgot to enable the necessary kernel config bits. I2C in Android/RemixOS can't work.
Hmmm....
Thanks for your reply!
Is there any way how to include I2C in kernel? Maybe rebuild it? You share the link where can I find this config file. Thanks in advance
p.s.: I was wrong, the power pin from pi-2 is working, my device (BMP180) doesn't have a led (forgot about it), so I attached it to +5v of pi-2 and GND of pi-2 and screened logs from arduino (where I use 2 pins of i2c)
  sourround sound - Remix MrSarkasmus 0 4,939 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 62,166 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 6,778 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 243,823 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,301 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,107 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,031 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 33,088 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,040 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,410 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
