ARM audio recording/editing.
Hello all!
I currently use JACK/Ardour for recording via a Focusrite Scarlett 2i2 USB A to D box on my desktop/laptop. There is no ARM version of Ardour, but I would LOVE a fanless portable linux box to record multiple tracks.
Are there any recommendations out there for me to use to put my PINE 64 and Focusrite to work as a portable audio recorder/editor?
Thanks in advance!
MB
hello there
the Debian Jessie image I am releasing tomorrow has the means to install it
amb-plugins - ambisonics LADPSA plugins
ardour - digital audio workstation (graphical gtk2 interface)
ardour-dbg - digital audio workstation (debug)
ardour3 - digital audio workstation (graphical gtk2 interface)
calf-plugins - Calf Studiogear - audio effects and sound generators
fil-plugins - parametric equalizer LADSPA plugin
gjacktransport - access to the JACK's transport mechanism as touchable slider
harvid - HTTP Ardour Video Server
so-synth-lv2 - Set of synthesizers for the LV2 plugin format
swh-lv2 - Steve Harris's SWH plugins ported to LV2
tap-plugins - Tom's Audio Processing LADSPA plugins
tap-plugins-doc - TAP-plugins documentation
xjadeo - Video player with JACK sync
Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
Thanks for heads up. Will I have to Sudo apt-get install each of the packages you listed?
I have the 5/8 MATE image running now. So very glad you (well, Longsleep and you) have this running at 720P, it widens my possible monitor usage!
MB
sudo apt-get install ardour should install all required packages including Jack last I checked
Cheers Big Grin
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,386 11-13-2019, 09:41 AM
Last Post: roel
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,532 01-19-2019, 11:31 AM
Last Post: ramstadt
  Bluetooth audio sink jszmidt 1 4,863 01-16-2017, 12:53 PM
Last Post: xalius
  Audio Mixer Settings from Android xalius 0 4,596 07-24-2016, 05:12 AM
Last Post: xalius
