Bugs I'm dealing with
These are the issues holding me back from using my A64 2gb board full time.  I thought about making a post for each one but some are known and I thought putting it in one place would help get it on the radar faster.
Any help that you could give that I might have missed on the forum would be great.
*Note that I'm using the latest Android image as of this post (5.1.1 Image Release 20160428)
1. Ethernet needs to work at gigabit speeds (known bug)
2. Sound issue with headphone jack (have to unplug and plug in again to work).  HDMI audio works fine.
3. The last two apps I need to have working are buggy or not supported.
   -Google Play Music (tried using a different apk but didn't work).  It opens up and appears to run fine but will just skip songs over and over without playing anything.
   -MLB At Bat (shows as not compatible in the store and did not work with side-loaded apk).  Won't play video as it says the device is not supported.  Could this be fixed by spoofing as a different device?
Aside from those it's been working well for me.
Thanks.
Hey,
Has issue nr 2 been reported already ? (not much of an android person so I dont know) - if not make sure to take it to bugs section.
Cheers!
