i got my 2gb pine64 yesterday.
- i first tried to install android (latest rooted version) but all i got was the red led. btw: i created the flashcard using the "usb image tool", as phoenix did not accept this image.
- next try i gave to the android phoenix card image, which i burnt using the phoenix tool. creating the flashcard succeeded on the 2nd try. again the same effect. only the red led.
- 3rd try i was using debian jessie. again the same. nothing but the red led ;-(
i did this test using a kingston 16gb micro sd, which was tested to be fine and has successfully been used with a raspi before.
i tried two power supplies which both are rated 2A and have been used with a raspi.
all i have connected to the pine64 is the hdmi monitor.
i measured the current, drawn from the power supply. after turning on, it's at about 400mA, going down to in between 250mA and 300mA after some time.
what else can i do?
looks like i got a dead one ;-(
what else can i do?
