Error importing PyQt5
Hi everyone,
I am looking into building GUIs with Python on postmarketOS.  I am (currently) using plasma-mobile so I figured it would make sense to use PyQt5, maybe with Kirigami.  So I installed py3-qt5 (version 5.13.1-r1) from the community repository using APK.  However, when I go to import QtGui from PyQt5 in python3 I get the following error:
Python 3.8.1 (default, Jan 19 2020, 11:48:03)
[GCC 9.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from PyQt5 import QtGui
Traceback (most recent call last):
 File "<stdin>", line 1, in <module>
ImportError: Error relocating /usr/lib/python3.8/site-packages/PyQt5/QtGui.so: _ZNK17QOpenGLTimerQuery16waitForTimestampEv: symbol not found
Trying to import QtWidgets gives the same error.
As well as the required dependencies for py3-qt5, I also installed py3-opengl to see if it would solve the problem (given the content of the error message) but it didn't help.  I also installed qutebrowser and its dependencies and, although I can't see the full error message it returns, it appears to have the exact same problem.  The full list of packages I have installed can be found at https://pastebin.com/HmgzaNPm.
Can anyone shed any light of what is wrong here?  Googling around doesn't really yield any relevant results.  I am reasonably familiar with Python but less so with Qt or C++.  So I'm not sure if I am missing something here.
Thanks!
Seems like PyQt5 needs a rebuild. However, I just tried the same on my Alpine laptop (running the latest edge) and it works fine, so I guess it has been rebuild already.
Please update your system, `apk update && apk upgrade -a`, and try again
Hi there, thanks for your advice. I ran update and upgrade -a and the issue remains. For the record, py3-qt5 was not upgraded (nor were any qt-related packages).
Interesting that you do not have the same issue on your laptop. Is anyone able to replicate this on a pinephone?
Although "upgrade -a" should've already installed the latest version available, could you verify that you have py3-qt5 version 5.13.1-r1 installed? "apk list -I | grep py3-qt5"
Confirmed:
py3-qt5-5.13.1-r1 aarch64 {py3-qt5} (GPL-2.0-or-later) [installed]
Well I guess the only thing you can do then is rebuild the package yourself.
I had the same bug. I reported it to alpine linux's aports here: https://gitlab.alpinelinux.org/alpine/ap...sues/11244
trying to build py3-qt5 with the supplied APKBUILD results in:
>>> py3-qt5: Analyzing dependencies...
  mesa-git-gbm-0_git20200202-r2:
    breaks: mesa-dev-19.3.4-r1[mesa-gbm=19.3.4-r1]
    satisfies: mesa-git-dri-gallium-0_git20200202-r2[mesa-git-gbm]
               xorg-server-1.20.7-r0[so:libgbm.so.1]
               kwin-5.18.1-r1[so:libgbm.so.1]
               qt5-qtbase-x11-9999-r17[so:libgbm.so.1]
               xdg-desktop-portal-kde-5.18.1-r1[so:libgbm.so.1]
               mesa-git-egl-0_git20200202-r2[so:libgbm.so.1]
               xorg-server-xwayland-1.20.7-r0[so:libgbm.so.1]
  mesa-git-glapi-0_git20200202-r2:
    breaks: mesa-dev-19.3.4-r1[mesa-glapi=19.3.4-r1]
    satisfies: mesa-git-dri-gallium-0_git20200202-r2[mesa-git-glapi]
               mesa-git-dri-gallium-0_git20200202-r2[so:libglapi.so.0]
               mesa-git-gl-0_git20200202-r2[so:libglapi.so.0]
               mesa-git-gles-0_git20200202-r2[so:libglapi.so.0]
               mesa-git-egl-0_git20200202-r2[so:libglapi.so.0]
               mesa-git-osmesa-0_git20200202-r2[so:libglapi.so.0]
  mesa-git-egl-0_git20200202-r2:
    breaks: mesa-dev-19.3.4-r1[mesa-egl=19.3.4-r1]
    satisfies: mesa-git-dri-gallium-0_git20200202-r2[mesa-git-egl]
               gst-plugins-base-1.16.2-r2[so:libEGL.so.1]
               qt5-qtwayland-5.12.5-r3[so:libEGL.so.1]
               qt5-qtbase-x11-9999-r17[so:libEGL.so.1]
               plasma-framework-5.67.0-r1[so:libEGL.so.1]
               kwayland-5.67.0-r1[so:libEGL.so.1]
  mesa-git-gl-0_git20200202-r2:
    breaks: mesa-dev-19.3.4-r1[mesa-gl=19.3.4-r1]
    satisfies: mesa-git-dri-gallium-0_git20200202-r2[mesa-git-gl]
               charging-sdl-0.1-r1[mesa-gl]
               osk-sdl-0.54-r0[mesa-gl]
               gst-plugins-base-1.16.2-r2[so:libGL.so.1]
               v4l-utils-1.18.0-r0[so:libGL.so.1]
               xorg-server-1.20.7-r0[so:libGL.so.1]
               qt5-qtwayland-5.12.5-r3[so:libGL.so.1]
               qt5-qtmultimedia-5.12.5-r2[so:libGL.so.1]
               qt5-qtwebkit-5.9.1-r9[so:libGL.so.1]
               plasma-framework-5.67.0-r1[so:libGL.so.1]
               xorg-server-xwayland-1.20.7-r0[so:libGL.so.1]
  mesa-git-gles-0_git20200202-r2:
    breaks: mesa-dev-19.3.4-r1[mesa-gles=19.3.4-r1]
    satisfies: mesa-git-dri-gallium-0_git20200202-r2[mesa-git-gles]
               qt5-qtbase-x11-9999-r17[so:libGLESv2.so.2]
  mesa-git-osmesa-0_git20200202-r2:
    breaks: mesa-dev-19.3.4-r1[mesa-osmesa=19.3.4-r1]
  mesa-git-xatracker-0_git20200202-r2:
    breaks: mesa-dev-19.3.4-r1[mesa-xatracker=19.3.4-r1]
As per the alpinelinux dev's request. I have reported the issue on pmos issue tracker: https://gitlab.com/postmarketOS/pmaports/issues/454
Ah yeah the mesa-git mess is a pmOS specific bug, py3-qt5 not working in the first place is an Alpine Linux one.
Thanks both! It's good to know that at least it's reproducible, and thanks anjanmomi for filing the issue.
Btw the original issue of this thread is now resolved. Just upgrade your system!
apk update
apk upgrade --available
(note the "--available" switch)
  constant apk error message iwm 2 5,299 11-15-2021, 07:25 PM
Last Post: iwm
  Error when updating syrinx 1 4,075 03-06-2021, 01:32 AM
Last Post: hiimtye
  pmbootstrap error lat 2 7,848 12-22-2020, 06:32 PM
Last Post: lat
  chroot can't execute passwd exec format error dimm82 5 10,142 09-18-2020, 07:53 AM
Last Post: krsmith28p
Sad ERROR: Could not find dependency 'firmware-rtl8723bt' Engineer 4 10,264 06-16-2020, 12:29 PM
Last Post: Engineer
