02-15-2020, 10:11 AM
Hi all,
As the title says, usually the FPS from glxgears should be near display's refresh rate.
Regardless of the OS, all of them show 36FPS, does that mean the screen's refresh rate is that low?
If not, why on earth the frame rate is that low? I set the governor to performance (to rule out CPU bottle neck), but nothing changed.
Thanks.
Thanks.
