01-30-2020, 07:56 PM
I want to make sure I'm not cooking my board. I'd also like to ensure its getting enough power.
With raspberry pi:
can be used to determine if throttling is happening, has happened. Along with under voltage detection (etc.)
Is there anyway to do something similar with rock64 under linux (any distribution)? Main thing I'd like to check is if throttling is happening or do I need to check temperature and use that as the indicator depending on what thresholds are set?
Is there a way at run time to determine the thresholds set in https://github.com/ayufan-rock64/linux-k...4.dts#L734 ?
With raspberry pi:
vcgencmd get_throttled
