Doubts about Bootloader
Hello all,
I have tried to build Rockpro64 bootloader..
But I am still confused with the methodology/ tools used..
I am using ATF mainline + u-Boot..
But it seems that the boards uses OPTEE Trusted Execution Environment instead of ATF?
Is this scheme bellow correct?
+--------+----------------+----------+-------------+---------+ | Boot   | Terminology #1 | Actual   | Rockchip    | Image   | | stage  |                | program  |  Image      | Location| | number |                | name     |   Name      | (sector)| +--------+----------------+----------+-------------+---------+ |        |                |          |             |         | | 2      |  Secondary     | U-Boot  |idbloader.img| 0x40    | pre-loader |        |  Program       | TPL/SPL |             |         | |        |  Loader (SPL)  |          |             |         | | 3      |  -             | U-Boot | u-boot.itb  | 0x4000  | including u-boot and atf |        |                |          |             |         | | 4      |  -             | /boot  | boot.img    | 0x8000  | |        |                |          |             |         | | 5      |  -             | / | rootfs.img  | 0x40000 | +--------+----------------+----------+-------------+---------+ Does I need OPTEE 'tee.bin'( renamed as bl31.elf )?? I am already using ARM Trusted Firmware bl31.elf.. Can somebody help me? Thanks in Advance, Best Regards tux
  How to revert to stock bootloader? nyankat 5 10,293 03-05-2021, 01:42 AM
Last Post: LMM
