Remix OS Issues
I am using a 2gb board.
Most of the issues seems to be already found
1. Internet speed issue
2.  Cannot install any apps from play store,just keeps saying downloading,
3. Screen size issue.
Overall responsiveness is ok to me
1. Im not sure if there is a fix yet
2. I had the same issue when downloading HBONow. It just said "Downloading" for the longest time. Honestly, I didnt do anything specific to fix it. I closed out the Playstore and opened it back up and everything was fine. Ive downloaded a few other apps since with no issues.
3. I also had this issue. Check to see if your tv has a "Fit to Screen" option. This fixed it for me.
What image and card are you using?
1) have you tried switching between 100/1000 connections? - sometimes you can set it in your router.
take a look at known bugs and issues: http://forum.pine64.org/showthread.php?tid=792
  sourround sound - Remix MrSarkasmus 0 5,147 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 63,927 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 7,015 07-14-2018, 11:48 AM
  Remix OS NMancuso 111 250,842 08-01-2017, 03:51 AM
Last Post: wappi
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 7,537 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 7,329 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 25,571 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 33,736 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 13,396 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 6,628 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
