Fedora 31 has now support for PineH64 Board.
Download the image here --> https://alt.fedoraproject.org/alt/
Similar to Armbian you can have different flavours like Server, Minimal, Workstation, Cloud etc.
To get the image onto your H64 do the following:
sudo dnf install arm-image-installer uboot-images-armv8
sudo arm-image-installer --image=/home/YOURuser/Downloads/Fedora-Workstation-31-1.9.aarch64.raw.xz --target=pine_h64 --media=/dev/sd? (use lsblk to find media)
It takes about 2min15sec from applying power to fully booted Desktop Environment.
It's a full Gnome 3 Desktop like on x86 with Firefox, LibreOffice and other apps pre-installed.
WiFi and Audio do NOT work at the moment (Fedora-Workstation-31-1.9).
And Video playback speed varies from slideshow on FullHD to acceptable on SVGA resolution.
Also there is NO support for eMMc only SD-Card works.
Other supported boards are: pine64-lts, pine64_plus, pinebook and sopine_baseboard amongst a variety of other makes.
