Tickety-Tickety-Tock...
...the phone run down the clock.
There I was at 8pm, but it seems Braveheart is still in the dressing room.
I will keep looking and hope I won't miss out on the chance to order one.
I need to get out of home .... but I have to order my phone before that ...
It has appeared: https://store.pine64.org/?product=pineph...ly-adaptor
Got one, thank you so much Skirmisher
As a tip for anyone else, make sure you have only the pinephone in your cart, otherwise you wont be able to select a shipping method
thx mfasfk215124!
I had the 3.5mm audio-socket serial console cable in there (rumoured to work also with the pine phone), and was stuck.
\freff
OK, thanks. Got one as well. :-)
Got mine Big Grin
Pine64 email confirmation @ 09:32:52 GMT
p.s. - looking forward to my early adaptor!
Hi Dukla,
No, YOU are an early adopter. :-)
This is a marketing term relating to the life cycle of a product and its uptake by customers:
Innvators
Early Adopters
Early Majority
Late Majority
Laggards
In the past I was proud to stay "at the trailing edge" of technology, making old stuff work for my needs. (perhaps more on that later)
But for once, I decided to join in as an early adopter.
Users browsing this thread:
