11-01-2019, 03:02 PM
Did not boot. Might have to flash to IT mode if possible. Will try later. Serial output:
DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 248
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=15262MB
FwPartOffset=2000 , 0
StorageInit ok = 44206
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xd35dc
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):370ab80
NOTICE: BL31: Built : 09:23:41, Mar 4 2019
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09 (May 31 2019 - 10:20:19 -0400)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM: 3.9 GiB
Sysmem: init
Relocation Offset is: f5bfa000
I2c speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_log init 900000 uV
rk_board_init PWM2 pinctrl init fail!
DCDC_REG1@ vdd_center: 750000uV <-> 1400000uV, set 900000uV, enabling | suspend -61uV, disabled
DCDC_REG4@ vcc_1v8: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
LDO_REG1@ vcc1v8_dvp: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
LDO_REG4@ vcc_sd: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend 3300000uV, enabling
LDO_REG7@ vcca1v8_codec: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend 1800000uV, enabling
LDO_REG8@ vcc_3v0: 3000000uV <-> 3000000uV, set 3000000uV, enabling | suspend 3000000uV, enabling
SWITCH_REG2@ vcc3v3_s0: -61uV <-> -61uV, set 0uV, enabling | suspend -61uV, disabled
dc-12v@ dc_12v: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend -61uV, enabling (ret: -38)
vcc-sys@ vcc_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend -61uV, enabling (ret: -38)
vcc3v3-sys@ vcc3v3_sys: 3300000uV <-> 3300000uV, set 3300000uV, enabling | suspend -61uV, enabling (ret: -38)
vcc-phy-regulator@ vcc_phy: -61uV <-> -61uV, set -61uV, enabling | suspend -61uV, enabling
vcc5v0-host-en@ vcc5v0_host: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend -61uV, enabling (ret: -38)
vcc5v0-typec0-en@ vcc5v0_typec0: -61uV <-> -61uV, set -61uV, disabled | suspend -61uV, enabling
vcc5v0-sys@ vcc5v0_sys: 5000000uV <-> 5000000uV, set 5000000uV, enabling | suspend -61uV, enabling (ret: -38)
vcc12v-pcie-regulator@ vcc12v_pcie: 12000000uV <-> 12000000uV, set 12000000uV, enabling | suspend -61uV, enabling (ret: -38)
vdd_log@ vdd_log: 800000uV <-> 1400000uV, set 900000uV, enabling | suspend -61uV, enabling ; init 900000uV
vcc1v8-sdio@ vcc1v8_sdio: 1800000uV <-> 1800000uV, set 1800000uV, enabling | suspend -61uV, enabling (ret: -38)
MMC: dwmmc@fe310000: 2, sdhci@fe330000: 0, dwmmc@fe320000: 1
Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: serial
Out: serial
Err: serial
RKPARM: Invalid parameter part table
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test found IDB in SDcard
Bootdev(atags): mmc 1
PartType: DOS
get part misc fail -1
boot mode: None
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Hit key to stop autoboot('CTRL+C'): 0
Could not find misc partition
ANDROID: reboot reason: "(none)"
load_android_image: Can't find part: boot
Android boot failed, error -1.
=Booting Rockchip format image=
boot_rockchip_image kernel or boot part info error
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
404 bytes read in 3 ms (130.9 KiB/s)
1: ROCKPRO
Retrieving file: /Image
reading /Image
25612296 bytes read in 2715 ms (9 MiB/s)
append: console=ttyS2,1500000n8 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=22:a4:46:f5:6e:39 eth1addr= serial=89f3230060b7d7e0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 video=HDMI-A-1:1920x1080@60 video=eDP-1:1920x1080@60 quiet loglevel=3 vga=current
Retrieving file: /rk3399-rockpro64.dtb
reading /rk3399-rockpro64.dtb
96363 bytes read in 14 ms (6.6 MiB/s)
## Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
Loading Device Tree to 00000000e9dc7000, end 00000000e9de186a ... OK
Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
Total: 3854.12 ms
Starting kernel ...
[UNSUPP] Starting of Arbitrary Executable Fi…tem Automount Point not supported.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Reached target Encrypted Volumes.
[ OK ] Reached target Swap.
Starting Restore / save the current clock...
Starting Journal Service...
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Reached target Slices.
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Load Kernel Modules.
Mounting FUSE Control File System...
Mounting Configuration File System...
Starting Apply Kernel Variables...
Starting Load/Save Random Seed...
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
[ OK ] Mounted Configuration File System.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Restore / save the current clock.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Raise network interfaces...
Starting udev Kernel Device Manager...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage...
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Boot and Home Patition Mount Service.
Starting System Logging Service...
[ OK ] Started D-Bus System Message Bus.
Starting LSB: Starts and stops Wicd...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Regular background program processing daemon.
Starting Save/Restore Sound Card State...
Starting LSB: IPv4 DHCP client with IPv4LL support...
Starting Login Service...
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Reached target Timers.
[ OK ] Started System Logging Service.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Found device /dev/ttyS2.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Login Service.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Sound Card.
Starting Load/Save RF Kill Switch Status...
[ OK ] Started Raise network interfaces.
[ OK ] Reached target Network.
Starting OpenBSD Secure Shell server...
[ OK ] Reached target Network is Online.
Starting LSB: Start NTP daemon...
Starting Permit User Sessions...
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Started Permit User Sessions.
[ OK ] Started Serial Getty on ttyS2.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Started LSB: IPv4 DHCP client with IPv4LL support.
[ OK ] Started LSB: Start NTP daemon.
[ OK ] Started OpenBSD Secure Shell server.
[ 2.894903] Internal error: : 96000210 [#1] SMP
[ 2.895308] Modules linked in: phy_rockchip_pcie midgard_kbase dw_hdmi_i2s_audio rockchip_saradc
[ 2.896109] CPU: 1 PID: 159 Comm: kworker/u12:3 Not tainted 4.4.180 #1
[ 2.896682] Hardware name: Pine64 RockPro64 (DT)
[ 2.897103] Workqueue: deferwq deferred_probe_work_func
[ 2.897568] task: ffffffc0f1484380 task.stack: ffffffc0f1550000
[ 2.898093] PC is at rockchip_pcie_rd_conf+0x164/0x1b4
[ 2.898545] LR is at rockchip_pcie_rd_conf+0x154/0x1b4
[ 2.898995] pc : [<ffffff80084a1220>] lr : [<ffffff80084a1210>] pstate: 600001c5
[ 2.899639] sp : ffffffc0f15537e0
[ 2.899932] x29: ffffffc0f15537e0 x28: 0000000000000000
[ 2.900407] x27: 0000000000000001 x26: 0000000000000000
[ 2.900880] x25: 0000000000000000 x24: ffffffc0eed85000
[ 2.901355] x23: 0000000000000000 x22: 0000000000000004
[ 2.901829] x21: ffffffc0f0b2f028 x20: ffffffc0f155386c
[ 2.902302] x19: ffffff8014100000 x18: 0000000000000005
[ 2.902775] x17: 0000000000000000 x16: ffffff800811518c
[ 2.903248] x15: 0000000000000000 x14: 000000000000000a
[ 2.903724] x13: ffffff80898f48e7 x12: 0000000000000030
[ 2.904197] x11: 0000000000000006 x10: ffffff80098f48ef
[ 2.904669] x9 : 0000000005f5e0ff x8 : 616373203a31303a
[ 2.905141] x7 : 3030303020737562 x6 : ffffff80098f4914
[ 2.905614] x5 : ffffff80084a10bc x4 : 0000000000000000
[ 2.906086] x3 : 000000000000000b x2 : 0000000000000800
[ 2.906559] x1 : ffffff8012c00008 x0 : ffffff8014000000
[ 2.907032]
[ 2.907032] PC: 0xffffff80084a11a0:
[ 2.907468] 11a0 54fffd01 39400042 12001c42 17fffff3 53140a73 12002ef7 53111000 2a170273
[ 2.908222] 11c0 2a025000 71007c5f 2a000273 540000e9 f94056a0 90007921 911e8c21 94048ad1
[ 2.908991] 11e0 b900029f 17ffffe0 510006c0 6a13001f 54fffa81 f9400b00 39436000 6b01001f
[ 2.909748] 1200 54000181 52800141 aa1503e0 97fffa39 710012df 54000121 f94002a0 8b130013
[ 2.910500] 1220 b9400273 d5033d9f b9000293 17ffffd5 52800161 17fffff5 71000adf 540000c1
[ 2.911250] 1240 f94002a0 8b130013 79400273 12003e73 17fffff5 710006df 54fff741 f94002a0
[ 2.912012] 1260 8b130013 39400273 12001e73 17ffffee a9be7bfd 910003fd a90153f3 aa0003f4
[ 2.912764] 1280 aa0103f3 aa1e03e0 d503201f d2800002 52800000 38626a81 91000442 eb02027f
[ 2.913517]
[ 2.913517] LR: 0xffffff80084a1190:
[ 2.913955] 1190 79400042 12003c42 17fffff8 710006df 54fffd01 39400042 12001c42 17fffff3
[ 2.914709] 11b0 53140a73 12002ef7 53111000 2a170273 2a025000 71007c5f 2a000273 540000e9
[ 2.915461] 11d0 f94056a0 90007921 911e8c21 94048ad1 b900029f 17ffffe0 510006c0 6a13001f
[ 2.916214] 11f0 54fffa81 f9400b00 39436000 6b01001f 54000181 52800141 aa1503e0 97fffa39
[ 2.916966] 1210 710012df 54000121 f94002a0 8b130013 b9400273 d5033d9f b9000293 17ffffd5
[ 2.917717] 1230 52800161 17fffff5 71000adf 540000c1 f94002a0 8b130013 79400273 12003e73
[ 2.918466] 1250 17fffff5 710006df 54fff741 f94002a0 8b130013 39400273 12001e73 17ffffee
[ 2.919218] 1270 a9be7bfd 910003fd a90153f3 aa0003f4 aa0103f3 aa1e03e0 d503201f d2800002
[ 2.919970]
[ 2.919970] SP: 0xffffffc0f1553760:
[ 2.920405] 3760 00000004 00000000 00000000 00000000 eed85000 ffffffc0 00000000 00000000
[ 2.921157] 3780 00000000 00000000 00000001 00000000 00000000 00000000 f15537e0 ffffffc0
[ 2.921906] 37a0 084a1210 ffffff80 f15537e0 ffffffc0 084a1220 ffffff80 600001c5 00000000
[ 2.922655] 37c0 00100000 00000000 f155386c ffffffc0 ffffffff ffffffff 08f91428 ffffff80
[ 2.923407] 37e0 f1553820 ffffffc0 08480054 ffffff80 0975e080 ffffff80 eed85000 ffffffc0
[ 2.924158] 3800 00000000 00000000 00000140 00000000 f15538ec ffffffc0 00000000 00000000
[ 2.924910] 3820 f1553870 ffffffc0 0848210c ffffff80 f15538ec ffffffc0 eed85000 ffffffc0
[ 2.925660] 3840 eed85000 ffffffc0 00000000 00000000 0000ea60 00000000 00000000 00000000
[ 2.926412]
[ 2.926412] X0: 0xffffff8013ffff80:
[ 2.926847] ff80 ******** ******** ******** ******** ******** ******** ******** ********
[ 2.927603] ffa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2.928356] ffc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2.929108] ffe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 2.929860] 0000
[ 2.930019] Synchronous External Abort: synchronous external abort (0x96000210) at 0xffffff8014000000
[ OK ] Started LSB: Starts and stops Wicd.
[ OK ] Reached target Multi-User System.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
[ 3.500186] failed to power up DHD generic adapter, 1 retry left
[ 3.516145] wifi_platform_set_power = 0
[ 3.516485] ======== PULL WL_REG_ON(-1) LOW! ========
[ 3.516930] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.517382] [WLAN_RFKILL]: wifi shut off power.
[ 3.517783] wifi_platform_bus_enumerate device present 0
[ 3.518274] ======== Card detection to remove SDIO card! ========
[ 3.518809] sdio: host isn't initialization successfully.
[ 3.519388] wifi_platform_set_power = 1
[ 3.519728] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 3.520204] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 3.520619] [WLAN_RFKILL]: wifi turn on power. -1
[ 3.821085] wifi_platform_bus_enumerate device present 1
[ 3.821552] ======== Card detection to detect SDIO card! ========
[ 3.822098] sdio: host isn't initialization successfully.
[ 3.964178] vendor storage:20160801 ret = -1
[ 5.822200] failed to power up DHD generic adapter, 0 retry left
[ 5.838919] wifi_platform_set_power = 0
[ 5.839270] ======== PULL WL_REG_ON(-1) LOW! ========
[ 5.839713] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 5.840136] [WLAN_RFKILL]: wifi shut off power.
[ 5.840534] wifi_platform_bus_enumerate device present 0
[ 5.840996] ======== Card detection to remove SDIO card! ========
[ 5.841532] sdio: host isn't initialization successfully.
[ 5.842011] failed to power up DHD generic adapter, max retry reached**
[ 5.843116] unregister wifi platform drivers
[ 5.843492] wifi_platform_bus_enumerate device present 0
[ 5.843956] ======== Card detection to remove SDIO card! ========
[ 5.844505] sdio: host isn't initialization successfully.
[ 5.844983] ======== dhd_wlan_deinit_plat_data ========
[ 5.845452] dhd_module_init: Failed to load the driver, try cnt 0
[ 5.846005] dhd_module_init: Failed to load driver max retry reached**
[ 5.846584] dhd_module_init: Exit err=-19
Debian GNU/Linux 9 localhost ttyS2
localhost login: [ 9.930845] BUG: spinlock lockup suspected on CPU#1, kworker/u12:3/159
[ 9.931424] lock: 0xffffff80096e0018, .magic: dead4ead, .owner: kworker/u12:3/159, .owner_cpu: 1
[ 9.932201] CPU: 1 PID: 159 Comm: kworker/u12:3 Not tainted 4.4.180 #1
[ 9.932771] Hardware name: Pine64 RockPro64 (DT)
[ 9.933183] Workqueue: deferwq deferred_probe_work_func
[ 9.933645] Call trace:
[ 9.933869] [<ffffff80080881a4>] dump_backtrace+0x0/0x220
[ 9.934343] [<ffffff80080883e8>] show_stack+0x24/0x30
[ 9.934790] [<ffffff80084245ec>] dump_stack+0x98/0xc0
[ 9.935235] [<ffffff80080e6c24>] spin_dump+0x84/0xa4
[ 9.935672] [<ffffff80080e6dc0>] do_raw_spin_lock+0xdc/0x164
[ 9.936174] [<ffffff8008f91428>] _raw_spin_lock_irqsave+0x28/0x38
[ 9.936708] [<ffffff8008088428>] die+0x34/0x1b4
[ 9.937107] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[ 9.937597] [<ffffff8008093324>] do_sea+0x80/0x94
[ 9.938012] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[ 9.938470] Exception stack(0xffffffc0f1553240 to 0xffffffc0f1553370)
[ 9.939035] 3240: ffffffc0f1484380 0000008000000000 ffffffc0f1553410 ffffff8008422884
[ 9.939720] 3260: 0000000000000000 0000000000000000 0000000000000005 0000000000000000
[ 9.940404] 3280: ffffff80098f5148 0000000000000000 ffffffc0f15532b0 ffffff80080eda14
[ 9.941088] 32a0: 0000000000000005 0000000000000000 ffffffc0f1553350 ffffff80080edb74
[ 9.941772] 32c0: ffffffc0f15533d0 ffffff800936ca08 ffffff800936ca08 ffffff80093c7fee
[ 9.942457] 32e0: ffffffc0f155349c ffffff8014000000 0000000000000004 00000040ee856000
[ 9.943142] 3300: 0000000000000002 ffffffc0f15534a0 ffffffc0f155349c 00000000ffffffff
[ 9.943826] 3320: ffffff800991081f 0000000005f5e0ff ffffff80098f48ef 0000000000000006
[ 9.944511] 3340: 0000000000000030 ffffff80898f48e7 000000000000000a 0000000000000000
[ 9.945195] 3360: ffffff800811518c 0000000000000000
[ 9.945624] [<ffffff80080825cc>] el1_da+0x24/0x84
[ 9.946039] [<ffffff8008084924>] show_data.constprop.3+0xa4/0xf8
[ 9.946566] [<ffffff8008084cac>] __show_regs+0x14c/0x198
[ 9.947032] [<ffffff80080884ac>] die+0xb8/0x1b4
[ 9.947431] [<ffffff800808869c>] arm64_notify_die+0x6c/0x70
[ 9.947920] [<ffffff8008093324>] do_sea+0x80/0x94
[ 9.948334] [<ffffff8008080b04>] do_mem_abort+0x50/0xa8
[ 9.948791] Exception stack(0xffffffc0f1553610 to 0xffffffc0f1553740)
[ 9.949355] 3600: ffffff8014100000 0000008000000000
[ 9.950040] 3620: ffffffc0f15537e0 ffffff80084a1220 ffffffc0eed85120 000000000000006e
[ 9.950724] 3640: ffffffc0f15537f0 0000000000000007 ffffff80093b3fe6 ffffff80093c1b86
[ 9.951409] 3660: ffffffc0f1553752 0000000000000000 ffffffc0f1553680 ffffff8009692000
[ 9.952093] 3680: 0000000000000140 00000000093c1b86 ffffffc0f1553860 ffffffc0f1553860
[ 9.952778] 36a0: ffffffc0f1553830 00000000ffffffd8 ffffff8014000000 ffffff8012c00008
[ 9.953462] 36c0: 0000000000000800 000000000000000b 0000000000000000 ffffff80084a10bc
[ 9.954147] 36e0: ffffff80098f4914 3030303020737562 616373203a31303a 0000000005f5e0ff
[ 9.954832] 3700: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7
[ 9.955516] 3720: 000000000000000a 0000000000000000 ffffff800811518c 0000000000000000
[ 9.956200] [<ffffff80080825cc>] el1_da+0x24/0x84
[ 9.956616] [<ffffff8008480054>] pci_bus_read_config_dword+0x6c/0xa4
[ 9.957174] [<ffffff800848210c>] pci_bus_read_dev_vendor_id+0x40/0xe4
[ 9.957739] [<ffffff8008483b3c>] pci_scan_single_device+0x60/0xc4
[ 9.958274] [<ffffff8008483c1c>] pci_scan_slot+0x7c/0xec
[ 9.958741] [<ffffff80084849dc>] pci_scan_child_bus+0x5c/0x164
[ 9.959252] [<ffffff8008484950>] pci_scan_bridge+0x4ac/0x4dc
[ 9.959748] [<ffffff8008484ad8>] pci_scan_child_bus+0x158/0x164
[ 9.960268] [<ffffff8008484cdc>] pci_scan_root_bus_msi+0x9c/0xe4
[ 9.960794] [<ffffff8008484d70>] pci_scan_root_bus+0x4c/0x60
[ 9.961292] [<ffffff80084a0130>] rockchip_pcie_really_probe+0x254/0x304
[ 9.961870] [<ffffff80084a0d50>] rockchip_pcie_probe+0xb70/0xcb4
[ 9.962399] [<ffffff80085caa24>] platform_drv_probe+0x5c/0xb0
[ 9.962904] [<ffffff80085c89bc>] driver_probe_device+0x2ac/0x3e8
[ 9.963431] [<ffffff80085c8c70>] __device_attach_driver+0x68/0xa4
[ 9.963966] [<ffffff80085c6874>] bus_for_each_drv+0x90/0xa0
[ 9.964456] [<ffffff80085c85f8>] __device_attach+0xac/0x128
[ 9.964945] [<ffffff80085c8cd0>] device_initial_probe+0x24/0x30
[ 9.965465] [<ffffff80085c794c>] bus_probe_device+0x38/0x98
[ 9.965954] [<ffffff80085c7f34>] deferred_probe_work_func+0xb4/0xc8
[ 9.966505] [<ffffff80080b2350>] process_one_work+0x224/0x368
[ 9.967009] [<ffffff80080b3438>] worker_thread+0x2d0/0x38c
[ 9.967492] [<ffffff80080b82ec>] kthread+0xe0/0xf0
[ 9.967914] [<ffffff8008082ef0>] ret_from_fork+0x10/0x20
[ 24.154121] Watchdog detected hard LOCKUP on cpu 1
[ 24.154535] ------------[ cut here ]------------
[ 24.154958] WARNING: at kernel/watchdog.c:352
[ 24.155340] Modules linked in: phy_rockchip_pcie midgard_kbase dw_hdmi_i2s_audio rockchip_saradc
[ 24.156128]
[ 24.156266] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.180 #1
[ 24.156790] Hardware name: Pine64 RockPro64 (DT)
[ 24.157195] task: ffffff80096de2d0 task.stack: ffffff80096d0000
[ 24.157717] PC is at watchdog_timer_fn+0x190/0x2e8
[ 24.158139] LR is at watchdog_timer_fn+0x190/0x2e8
[ 24.158560] pc : [<ffffff800812c738>] lr : [<ffffff800812c738>] pstate: 600001c5
[ 24.159204] sp : ffffffc0f7ed6d00
[ 24.159496] x29: ffffffc0f7ed6d00 x28: 0000000000000001
[ 24.159969] x27: ffffff80096d7720 x26: ffffff8009698260
[ 24.160441] x25: ffffffc0f7ed9278 x24: ffffff80096d3d70
[ 24.160913] x23: 0000000000000000 x22: 0000000000000012
[ 24.161385] x21: ffffff80096d6000 x20: ffffff80096982d8
[ 24.161858] x19: ffffff8009698000 x18: 0000000000000005
[ 24.162329] x17: 0000000000000000 x16: 0000000000000000
[ 24.162801] x15: 0000000000000000 x14: 000000000000000a
[ 24.163272] x13: ffffff80898f48e7 x12: 0000000000000030
[ 24.163744] x11: 0000000000000006 x10: ffffff80098f48ef
[ 24.164215] x9 : 0000000005f5e0ff x8 : 4c20647261682064
[ 24.164687] x7 : 6574636574656420 x6 : ffffff80098f491d
[ 24.165159] x5 : 00000000fffffffe x4 : 0000000000000002
[ 24.165630] x3 : 00000040ee841000 x2 : 00000040ee841000
[ 24.166102] x1 : 0000000000000000 x0 : 0000000000000026
[ 24.166574]
[ 24.166574] PC: 0xffffff800812c6b8:
[ 24.167009] c6b8 91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[ 24.167761] c6d8 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[ 24.168511] c6f8 f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[ 24.169262] c718 91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[ 24.170012] c738 d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[ 24.170764] c758 b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[ 24.171515] c778 6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[ 24.172266] c798 d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[ 24.173019]
[ 24.173019] LR: 0xffffff800812c6b8:
[ 24.173454] c6b8 91022694 d538d080 38746801 34000041 3834681f 97ffff7a a94153f3 52800020
[ 24.174206] c6d8 a9425bf5 a94363f7 a9446bf9 a94573fb a8c77bfd d65f03c0 91020282 f87a6860
[ 24.174958] c6f8 f8626865 91022294 eb05001f 54000101 38746860 35fffb80 b9403082 90009260
[ 24.175709] c718 91262c00 340000c2 9400d200 f8226860 f87c7b60 3834681f 17ffffd3 9400d28a
[ 24.176460] c738 d4210000 f87c7b60 52800021 38346801 17ffffcd 97fe7745 f9438aa1 36080941
[ 24.177212] c758 b9401341 910003e2 340008e1 531f7821 d35efc00 8b21c2c1 cb000021 b6f80841
[ 24.177963] c778 6b160016 54000800 91022a99 d538d080 38606b21 34000101 91024294 f8746802
[ 24.178716] c798 d5384101 eb01005f 54fff980 3839681f 17ffffc9 34000157 f000c161 52800000
[ 24.179466]
[ 24.179466] SP: 0xffffffc0f7ed6c80:
[ 24.179901] 6c80 00000012 00000000 00000000 00000000 096d3d70 ffffff80 f7ed9278 ffffffc0
[ 24.180651] 6ca0 09698260 ffffff80 096d7720 ffffff80 00000001 00000000 f7ed6d00 ffffffc0
[ 24.181402] 6cc0 0812c738 ffffff80 f7ed6d00 ffffffc0 0812c738 ffffff80 600001c5 00000000
[ 24.182154] 6ce0 096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[ 24.182902] 6d00 f7ed6d70 ffffffc0 08103104 ffffff80 f7ed9278 ffffffc0 f7ed8c00 ffffffc0
[ 24.183655] 6d20 9a174e5e 00000005 f7ed8c80 ffffffc0 09692000 ffffff80 00000001 00000000
[ 24.184406] 6d40 098a07b8 ffffff80 9a174e5e 00000005 0812c5a8 ffffff80 9a1740b2 00000005
[ 24.185156] 6d60 f7ed9278 ffffffc0 096d6710 ffffff80 f7ed6de0 ffffffc0 081036e8 ffffff80
[ 24.185910]
[ 24.185910] X6: 0xffffff80098f489d:
[ 24.186345] 489c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.187097] 48bc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.187848] 48dc 00000000 00000001 00000000 30303020 32303330 34383730 34205d38 20636438
[ 24.188600] 48fc 312e3432 31393538 58205d30 30203a36 66666678 38666666 38393030 39383466
[ 24.189351] 491c 300a3a64 32313830 38333763 70205d3e 74617473 36203a65 30303030 0a356331
[ 24.190102] 493c 30303030 656e770a 70635f72 31203a75 3030300a 6c6c750a 625b2029 30207375
[ 24.190854] 495c 66312d30 690a295d 0a216576 73203b29 65636375 69207373 6974696e 7020676e
[ 24.191605] 497c 7265776f 646f6d5f 735f6c65 6c706d69 6e0a2e65 79617779 504d0a2e 4c422b20
[ 24.192358] 499c 2044494b 464c452b 4c495455 4b2b2053 20444f4d 4e44492b 47200a29 5b0a2942
[ 24.193113]
[ 24.193113] X10: 0xffffff80098f486f:
[ 24.193554] 486c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.194301] 488c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.195051] 48ac 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.195803] 48cc 00000000 00000000 00000000 00000000 00000000 00000001 00000000 30303020
[ 24.196554] 48ec 312e3432 35353632 34205d34 20636538 312e3432 31313339 58205d33 203a3031
[ 24.197305] 490c 66667830 66666666 39303038 38346638 0a3a6636 32313830 38333763 70205d3e
[ 24.198057] 492c 74617473 36203a65 30303030 0a356331 30303030 656e770a 70635f72 31203a75
[ 24.198808] 494c 3030300a 6c6c750a 625b2029 30207375 66312d30 690a295d 0a216576 73203b29
[ 24.199559] 496c 65636375 69207373 6974696e 7020676e 7265776f 646f6d5f 735f6c65 6c706d69
[ 24.200312]
[ 24.200312] X13: 0xffffff80898f4867:
[ 24.200755] 4864 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.201509] 4884 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.202262] 48a4 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.203013] 48c4 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.203763] 48e4 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.204516] 4904 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.205270] 4924 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.206024] 4944 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.206775] 4964 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.207531]
[ 24.207531] X19: 0xffffff8009697f80:
[ 24.207973] 7f80 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.208725] 7fa0 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.209477] 7fc0 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.210229] 7fe0 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.210982] 8000 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.211735] 8020 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.212488] 8040 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.213240] 8060 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.213994]
[ 24.213994] X20: 0xffffff8009698258:
[ 24.214437] 8258 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.215188] 8278 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.215939] 8298 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.216691] 82b8 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.217442] 82d8 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.218195] 82f8 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.218948] 8318 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.219704] 8338 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.220457]
[ 24.220457] X21: 0xffffff80096d5f80:
[ 24.220900] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.221650] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.222400] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.223152] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.223902] 6000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.224653] 6020 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.225403] 6040 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.226155] 6060 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 24.226907]
[ 24.226907] X24: 0xffffff80096d3cf0:
[ 24.227349] 3cf0 00000000 00000000 096de2d0 ffffff80 000000c0 00000000 08c6cdb0 ffffff80
[ 24.228101] 3d10 00000001 00000000 080913c4 ffffff80 096d3d30 ffffff80 080914b8 ffffff80
[ 24.228853] 3d30 096d3e40 ffffff80 08c6d42c ffffff80 096d3d80 ffffff80 08cee258 ffffff80
[ 24.229606] 3d50 f252ea10 ffffffc0 f252e610 ffffffc0 f252e800 ffffffc0 00000002 00000000
[ 24.230358] 3d70 00000000 00000000 00000000 00000000 ee841000 00000040 00000001 00000000
[ 24.231107] 3d90 ffffffff 00ffffff 289e6297 00000000 0000b89c 00000000 00000000 00000000
[ 24.231857] 3db0 b5593519 00000032 08081800 ffffff80 00001000 00000000 00000000 00000000
[ 24.232609] 3dd0 34d5d91d 00000000 ee841000 00000040 096de2d0 ffffff80 00000000 00000000
[ 24.233361]
[ 24.233361] X25: 0xffffffc0f7ed91f8:
[ 24.233804] 91f8 ffffffff 00000000 ffffffff ffffffff 00000001 00000000 f7ed9210 ffffffc0
[ 24.234557] 9218 f7ed9210 ffffffc0 f7ed9220 ffffffc0 f7ed9220 ffffffc0 0812b194 ffffff80
[ 24.235308] 9238 f324bcf8 ffffffc0 f324bc50 ffffffc0 00020002 00000000 00000000 00000000
[ 24.236060] 9258 00000001 00000000 00000006 00000000 00000005 00000000 f3288000 ffffffc0
[ 24.236811] 9278 f7ed9278 ffffffc0 00000000 00000000 00000000 00000000 9a167700 00000005
[ 24.237562] 9298 9a167700 00000005 0812c5a8 ffffff80 f7ed8c80 ffffffc0 00000000 0000000a
[ 24.238314] 92b8 0812c57c ffffff80 63746177 676f6468 0000302f 00000000 00000000 00000000
[ 24.239067] 92d8 00000000 00000000 00000000 00000000 00000000 00000000 00000001 00000000
[ 24.239819]
[ 24.239819] X26: 0xffffff80096981e0:
[ 24.240262] 81e0 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.241015] 8200 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.241768] 8220 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.242521] 8240 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.243274] 8260 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.244029] 8280 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.244782] 82a0 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.245535] 82c0 ******** ******** ******** ******** ******** ******** ******** ********
[ 24.246288]
[ 24.246288] X27: 0xffffff80096d76a0:
[ 24.246731] 76a0 00000001 00000000 00000001 00000000 000003e8 00000000 f7f51500 ffffffc0
[ 24.247482] 76c0 00000015 00000000 f7f514c0 ffffffc0 00000001 00000006 00000060 00000000
[ 24.248235] 76e0 00015000 00001000 00000001 00000000 f7f51540 ffffffc0 f7f51580 ffffffc0
[ 24.248985] 7700 00000000 00000005 00000010 00000000 f7f513c0 ffffffc0 f7ed3000 ffffffc0
[ 24.249736] 7720 ee841000 00000040 ee856000 00000040 ee86b000 00000040 ee880000 00000040
[ 24.250488] 7740 ee895000 00000040 ee8aa000 00000040 00000000 00000000 00000000 00000000
[ 24.251239] 7760 00000002 00000000 00001af0 00000000 00010000 00000000 000f7fff 00000000
[ 24.251990] 7780 0001e290 00000000 00002000 00000000 00000000 0000fffa 00000000 00000000
[ 24.252743]
[ 24.252743] X29: 0xffffffc0f7ed6c80:
[ 24.253186] 6c80 00000012 00000000 00000000 00000000 096d3d70 ffffff80 f7ed9278 ffffffc0
[ 24.253937] 6ca0 09698260 ffffff80 096d7720 ffffff80 00000001 00000000 f7ed6d00 ffffffc0
[ 24.254687] 6cc0 0812c738 ffffff80 f7ed6d00 ffffffc0 0812c738 ffffff80 600001c5 00000000
[ 24.255439] 6ce0 096d6710 ffffff80 00000000 00000000 00000000 00000080 f2c00028 ffffffc0
[ 24.256190] 6d00 f7ed6d70 ffffffc0 08103104 ffffff80 f7ed9278 ffffffc0 f7ed8c00 ffffffc0
[ 24.256941] 6d20 9a174e5e 00000005 f7ed8c80 ffffffc0 09692000 ffffff80 00000001 00000000
[ 24.257693] 6d40 098a07b8 ffffff80 9a174e5e 00000005 0812c5a8 ffffff80 9a1740b2 00000005
[ 24.258445] 6d60 f7ed9278 ffffffc0 096d6710 ffffff80 f7ed6de0 ffffffc0 081036e8 ffffff80
[ 24.259195]
[ 24.259330] ---[ end trace 5f0a747bb1eb9978 ]---
[ 24.259734] Call trace:
[ 24.259952] Exception stack(0xffffffc0f7ed6b20 to 0xffffffc0f7ed6c50)
[ 24.260517] 6b20: ffffff8009698000 0000008000000000 ffffffc0f7ed6d00 ffffff800812c738
[ 24.261202] 6b40: 00000000600001c5 ffffff80080eda14 0000000000000026 0000000000000000
[ 24.261887] 6b60: ffffffc0f7ed6c00 ffffff80080edb74 ffffffc0f7ed6c80 ffffff800937898b
[ 24.262571] 6b80: ffffff80096d6000 0000000000000012 0000000000000000 ffffff80096d3d70
[ 24.263256] 6ba0: ffffffc0f7ed9278 ffffff8009698260 ffffff80096d7720 0000000000000001
[ 24.263940] 6bc0: 0000000000000000 ffffff8009692000 0000000000000026 0000000000000000
[ 24.264625] 6be0: 00000040ee841000 00000040ee841000 0000000000000002 00000000fffffffe
[ 24.265310] 6c00: ffffff80098f491d 6574636574656420 4c20647261682064 0000000005f5e0ff
[ 24.265994] 6c20: ffffff80098f48ef 0000000000000006 0000000000000030 ffffff80898f48e7
[ 24.266678] 6c40: 000000000000000a 0000000000000000
[ 24.267109] [<ffffff800812c738>] watchdog_timer_fn+0x190/0x2e8
[ 24.267623] [<ffffff8008103104>] __hrtimer_run_queues+0x1bc/0x284
[ 24.268156] [<ffffff80081036e8>] hrtimer_interrupt+0xac/0x1bc
[ 24.268662] [<ffffff800810f1c0>] tick_handle_oneshot_broadcast+0x144/0x1c0
[ 24.269268] [<ffffff8008c6de54>] rk_timer_interrupt+0x4c/0x5c
[ 24.269774] [<ffffff80080ef2fc>] handle_irq_event_percpu+0xf4/0x1f0
[ 24.270323] [<ffffff80080ef448>] handle_irq_event+0x50/0x80
[ 24.270814] [<ffffff80080f2d7c>] handle_fasteoi_irq+0xcc/0x134
[ 24.271325] [<ffffff80080ee7e0>] generic_handle_irq+0x2c/0x44
[ 24.271830] [<ffffff80080eeb74>] __handle_domain_irq+0xb4/0xb8
[ 24.272340] [<ffffff8008080e74>] gic_handle_irq+0xc4/0x17c
[ 24.272821] Exception stack(0xffffff80096d3d70 to 0xffffff80096d3ea0)
[ 24.273385] 3d60: 0000000000000000 0000000000000000
[ 24.274069] 3d80: 00000040ee841000 0000000000000001 00ffffffffffffff 00000000289e6297
[ 24.274754] 3da0: 000000000000b89c 0000000000000000 00000032b5593519 ffffff8008081800
[ 24.275438] 3dc0: 0000000000001000 0000000000000000 0000000034d5d91d 00000040ee841000
[ 24.276123] 3de0: ffffff80096de2d0 0000000000000000 0000000000000000 0000000000000000
[ 24.276807] 3e00: 0000000030d00800 000000059a1731e3 0000000000000001 ffffffc0f1d6bc00
[ 24.277492] 3e20: 0000000000000001 ffffff80098a0ce0 0000000000000001 000000059a074c39
[ 24.278177] 3e40: ffffff800983df50 000000000119323c 00000000017a001c ffffff80096d3ea0
[ 24.278861] 3e60: ffffff8008c43cfc ffffff80096d3ea0 ffffff8008c43d00 0000000060000045
[ 24.279546] 3e80: ffffff80096d3ea0 ffffff8008c43cfc ffffffffffffffff 0000000000000001
[ 24.280230] [<ffffff80080827b4>] el1_irq+0xb4/0x140
[ 24.280661] [<ffffff8008c43d00>] cpuidle_enter_state+0x1fc/0x254
[ 24.281187] [<ffffff8008c43dcc>] cpuidle_enter+0x34/0x44
[ 24.281655] [<ffffff80080e05b8>] call_cpuidle+0x70/0x78
[ 24.282113] [<ffffff80080e085c>] cpu_startup_entry+0x29c/0x2ac
[ 24.282626] [<ffffff8008f8cdd0>] rest_init+0x74/0x7c
[ 24.283063] [<ffffff80095a0bcc>] start_kernel+0x3d8/0x3fc
[ 24.283538] [<ffffff80095a01c4>] __primary_switched+0x30/0x6c
