using dd to clone image
Hi all,
I'm trying to burn arch to a microsd via
dd if=arch-pine64-bspkernel-20160403-1.img of=/dev/sdg1 bs=1M
the image burns fine, but once i eject/reinsert the microsd, my OS cannot mount or recognize the FS on the microsd.  Any help?
I run arch linux with XFCE here, and my kernel supports all the common FS's up to ext4fs, reiserfs, and ntfs.
(04-27-2016, 06:29 PM)jproffer Wrote: Hi all,
You are burning the image to the first partition, but you must burn it to the device, use sdg not sdg1
argh.. such a rookie mistake!  been a while Smile  Thanks!
  Arch Linux image (BSP Kernel) longsleep 28 100,794 05-06-2016, 06:33 PM
