Wayland Driver installtion
I'm very happy that they are at least producing wayland drivers however there aren't any instructions for installing the driversdon't know what applications I'm supposed to use for installation, or if I simple just put the files in the lib directory and then create system links.  I've gone thought the documentation folder as well and found nothing.  I could use some even if it just the applications that I'm supposed to use to build the driver for dpkg installation?
On a second note will there be OpenCL drivers built for the Pine H64 Model B as well in Linux for xll desktop hardware acceleration?
Any progress on this? I'd like to see OpenCL on the H64, since it's advertised as supporting it.
