Pin and libraries compatibility
Hi
I'm using the Pine A64+ (will update shortly to the LTS) for a project at work.
I need to use several I2C sensors and SPI sensors too.
Also, found the library for one of the sensors for RPi and I was wondering... the same tutorials/codes/examples/libraries from RPi work on the Pine A64??
I'm using Armbian Stretch, since I'm familiar with Debian
Thanks for the help
(06-03-2019, 12:40 PM)MikeA23 Wrote: Hi
Thanks for the help
check this out: http://synfare.com/599N105E/hwdocs/pine64/spidev.html
Users browsing this thread:
