NextCloudPi avaialble
NextCloudPi - a dedicated Nextcloud OS image with a convenient setup  - is now available for the RockPro64.
You can download the image from the NextCloudPi website.
(03-15-2019, 06:43 AM)Luke Wrote: NextCloudPi - a dedicated Nextcloud OS image with a convenient setup  - is not available for the RockPro64.
... ist now available for the RockPro64.
Can I keep the typo? Wink
(03-15-2019, 10:51 AM)bigCamel Wrote: ... ist now available for the RockPro64.
Dang, made a typo myself. Thank you German auto correction.
haha, funny indeed Wink thanks bigCamel
Any idea what the default username and password for the Rock64/Pro64 image is for this NextCloud install?
The documentation site is broken and doesn't offer any of that info. I posted this question a little bit ago on Reddit. If I get an answer I'll post it here, too.
Thanks!
Added NextCloudPi Community Build Image - 03-10-19 to Wiki and Pine64 Installer
I'm running Armbian on my RockPRO64 and when I try to pull the package via curl, I'm greeted with "distro not supported". Is there a specific Armbian version that needs to be used?
Anyone? Tap, tap, tap, is this on?
@Tim Jones since this is an Armbian specific question, you will likely have more luck over at the Armbian forum.
