Kicad library part
Hi All,
I promised this many many moons ago and here it is. Unzip this, and put the two files in your project library.
The delay is mostly that I keep evolving the library part so it's still a "work in progress" but does work, has been debugged as far as I know, and has been used for a production project. The sopine lib is broken into functional units rather than having all 204 pins on one block. There's one for power, gnd, hdmi, ethernet, etc ...
The footprint for it is for the TE_2013289_Debug. The manufacturer part number from TE is: 2-2013289-1
M.
.zip   SopineBlocks.zip (Size: 3.13 KB / Downloads: 752)
(02-28-2019, 02:31 AM)maya.b Wrote: Hi All,
M.
Thanks on sharing
And a new improved version, that's more compliant with Kicad's standard library layouts.
M.
.zip   SoPine.zip (Size: 2.49 KB / Downloads: 848)
(05-03-2020, 12:54 PM)maya.b Wrote: And a new improved version, that's more compliant with Kicad's standard library layouts.
M.
M.
I am having trouble determining which pin VRTC is connected too. According to this library, the VRTC is mapped to 195, the 1.0 pinlist says pin 195, but the module schematic states 197. Can anyone confirm which pin VRTC is attached too? I also noticed that the AXP809 RTC voltage is an alyways on output, but this library labels that pin as an input. Can you clarify? Thank you.
[img]data:image/png;base64,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[/img]
  SoPINE kicad part maya.b 0 4,946 02-24-2017, 06:39 AM
Last Post: maya.b
