NFS mount using 4.20rc4, ethernet help?
Does anyone have any hints on how to get an NFS mount working?  I am using kernel 4.20 since it recently had rockpro64 support added.  My kernel parameters look like the following:
console=ttyS2,1500000 earlycon=uart8250,mmio32,0xff1a0000 root=/dev/nfs rw nfsroot=10.10.0.1:/export/sysroot,proto=tcp,vers=3 ip=10.10.0.2:10.10.0.1::255.255.255.0:rockpro64:eth0:off raid=noautodetect nfsrootdebug
and I am loading my kernel and kicking it off from u-boot with:
tftpboot 0x2000000 <kernel Image>
tftpboot 0x20000000 rk3399-rockpro64.dtb
booti 0x2000000 - 0x20000000
The NFS debug spits out:
NFS: nfs mount opts='vers=2,udp,rsize=4096,wsize=4096,proto=tcp,vers=3,nolock,addr=10.10.0.1'
NFS:   parsing nfs mount option 'vers=2'
NFS:   parsing nfs mount option 'udp'
NFS:   parsing nfs mount option 'rsize=4096'
NFS:   parsing nfs mount option 'wsize=4096'
NFS:   parsing nfs mount option 'proto=tcp'
NFS:   parsing nfs mount option 'vers=3'
NFS:   parsing nfs mount option 'nolock'
NFS:   parsing nfs mount option 'addr=10.10.0.1'
NFS: MNTPATH: '/export/sysroot'
NFS: sending MNT request for 10.10.0.1:/export/sysroot
NFS: failed to create MNT RPC client, status=-101
NFS: unable to mount server 10.10.0.1, error -101
I am not convinced that the network interface is coming up.  For starters, I never see anything like the following on the console:
IP-Config: Complete:
      device=eth0, addr=192.168.1.100, mask=255.255.255.0, gw=255.255.255.255,
    host=myboard, domain=, nis-domain=(none),
    bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
which is what I thought using the ip= parameter was supposed to do and when I turn on:
rpcdebug -m nsfd all
rpcdebug -m rpc all
and watch /var/log/messages on my server, nothing happens - it looks like my devices aren't talking.
I assumed that the in kernel realtek drivers would be sufficient, but I noticed that in the 4.4 kernel, there is an actual rockchip ethernet driver - does that need to be used in the 4.20 kernel?  I tried copying it and adding it to my config, but some of the timer interfaces changed, so it does not compile.
Any hints would be helpful.
Thanks!
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 5,901 09-22-2023, 04:27 AM
Last Post: diederik
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 5,041 09-11-2021, 08:58 PM
Last Post: t4_4t
  Slow/dead ethernet on (non-Ayufan) Linux Mainline (fixed) mmatyas 1 6,076 04-17-2020, 02:53 AM
Last Post: Thra11
