12-02-2018, 12:38 PM
I have an odd problem. The IDE by Arduino has transparent fonts. It's usable only if the window below is dark, however the menus are unreadable, as they appear over the IDE itself.
I found out that disabling the window compositor solves this issue (alt+shift+f12) anyway it gives others, like an annoying flickering of the panel that sometimes disappears for a while.
I tried disabling the graphical eye candies, but with no luck. Only disabling the screen compositor works.
I'm running the stock Linux version.
