[SOLVED] HELP! Four clocks on panel!
I'm running Q4OS with KDE Plasma DE.
Somehow I managed to add 4 analog clock widgets to the panel. I can't find any way to delete a widget from the panel.
HELP!
I don't know about Q4OS but in KDE Plasma in general you activate the panel options first, that's the (hamburger) menu at the end of the panel and then you can hoover/move over a widget and a remove option should be shown.
Thank you, Surehand53. I see that option now.
  [SOLVED] Can't boot when SD card inserted jschall 5 13,651 11-17-2018, 11:53 AM
Last Post: jschall
