Linux not working properly (noobie)
First of all this is my first sbc and I might not doing somethings properly.tas fan from pine store, 16GB eMMC in NAS Metal Case.
I used "LXDE Desktop aarch64 [microSD / eMMC Boot] [0.7.9]"
1) How do you control the fan?
2) Is there any HW Acceleration? Youtube, daily motion are playing with 20-25 fps top.
I played with some kernels but didn't see any difference (only in sound, the known bug).
3) WiFi module doesn't work. Is this normal? I saw something in changelog. I also upgrade to 0.7.10 by changing apt lists and didn't see any difference.
4) Can't get the SATA PCIe work in graphic environment.
If I press ctrl+alt+f1 and login, I can see the PCIe card (lspci works), I can use parted, format the drive and mount it succesfully.
If I try to use LXDE everything freezes.
If I don't do anything with the drive, even lspci freezes the rpro64.
So my HDD is useless in desktop mode.
Is anyone experience the same problems?
Is there any Linux distribution that works without problems? Any kernel suggestion?
2. Yes, there is hw accel for playing full screen content with ffmpeg and mpv decoding with libmali/mpp (userland should be available as rkmpv in ubuntu, so I'm told [1]). I'm playing youtube videos with mpv and the youtube-dl module from the linux console. It works in X11, too - fullscreen. Inside a browser I got the best results with chromium, but that was just normal arm/neon decoding - so cpu load at 2.x and fps around 22.
[1] https://github.com/ayufan-rock64/linux-b...layback.md
(10-21-2018, 02:25 PM)hunderteins Wrote: 2. Yes, there is hw accel for playing full screen content with ffmpeg and mpv decoding with libmali/mpp (userland should be available as rkmpv in ubuntu, so I'm told [1]). I'm playing youtube videos with mpv and the youtube-dl module from the linux console. It works in X11, too - fullscreen. Inside a browser I got the best results with chromium, but that was just normal arm/neon decoding - so cpu load at 2.x and fps around 22.
GitHub is experiencing some Storage problems..
Maybe because of that your system is is panic mode..
https://twitter.com/githubstatus
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,693 09-27-2026, 11:42 AM
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,184 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,467 07-14-2023, 04:22 AM
Last Post: hunderteins
  Linux laptop does not detect the board when plugged in via USB soupy 1 7,899 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 linux console video mode callegar 0 2,933 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 18,402 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 11,840 01-03-2022, 10:32 AM
Last Post: whitecat23
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 4,690 10-29-2021, 11:15 AM
Last Post: TRS-80
  WORKING: GPU-accelerated Widevine Chromium for Ubuntu 64 twilite 0 4,067 09-13-2021, 11:02 AM
Last Post: twilite
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 6,382 07-14-2021, 02:37 PM
Last Post: TRS-80
