USB Wireless
Are you able to add a usb wireless? I have a couple different types and they all work with linux but nothing is working here. I was wondering if anyone has gotten a usb wireless to work and what they had to do.
(10-20-2018, 07:07 AM)y0sh Wrote: Are you able to add a usb wireless? I have a couple different types and they all work with linux but nothing is working here. I was wondering if anyone has gotten a usb wireless to work and what they had to do.
I have this adaptor:
https://www.pine64.org/?product=rock64-u...au-adapter
and I had to compile drivers as there is only 1 802.11ac driver in the kernel.
Thanks for the response I will have to research and see if I can figure out how to do that.
(10-20-2018, 06:05 PM)y0sh Wrote: Thanks for the response I will have to research and see if I can figure out how to do that.
What chipset are you after?
Either r8712u or rt2800usb
Took a quick look here:
https://github.com/ayufan-rock64/linux-k...elease-4.4
and it looks like there is drivers available, but the r8712u isn't included, you can file a PR to get this included, but the rt2800usb is included
/lib/modules/4.4.154-1122-rockchip-ayufan-g7859b9b904a9/kernel/drivers/net/wireless/rt2x00/rt2800usb.ko
Thanks for the help, not sure why it didnt work the first time i tried it but it is now.
(10-20-2018, 09:58 PM)evilbunny Wrote: ... but the r8712u isn't included, you can file a PR to get this included, ...
Appreciate the OP is now sorted - just FYI no need to file a PR to get modules included, Ayufan told me to learn to load modules when I tried a PR! Smile
I've flashed a microSD card with the build as specified in this thread, and also found a build on the same website that was updated yesterday. I've noticed that the PPSSPP emulator doesn't render FMV's (I get a bleeding effect), and the "update lakka" doesn't work at all.
I'm not familiar with linux at all, so I'm at a loss on how to get these working. The whole point of me getting a rockpro64 was for PS2 and PSP emulation. Any guesses on what I can do to get fmv's working for ppsspp?
  RockPro Wireless+Bluetooth Issue - Linux (ayufan 0.7.8 and previous) JeffD 23 47,719 09-16-2018, 12:08 AM
Last Post: romtorwator
