qemu-x86_64 fails on A72 cores, but runs nice on A53 ones :)
I have tried to emulate a chroot for x86_64 architecture and it gave me inconsistent results, random successes and fails:
jinks /disco2/chroot/amd64 # chroot . /bin/bash qemu: uncaught target signal 11 (Segmentation fault) - core dumped root@jinks / # exit exit jinks /disco2/chroot/amd64 # chroot . /bin/bash Instrucción ilegal jinks /disco2/chroot/amd64 # chroot . /bin/bash qemu: uncaught target signal 11 (Segmentation fault) - core dumped Violación de segmento jinks /disco2/chroot/amd64 # chroot . /bin/bash root@jinks / # ls Instrucción ilegal jinks /disco2/chroot/amd64 # bin   dev  home  lib32     media  opt   root  sbin  tmp  var boot  etc  lib   lib64  mnt    proc  run   sys   usr jinks /disco2/chroot/amd64 #
Finally I got it to work, by forbidding to run on the last 2 cores:
jinks /disco2/chroot/amd64 # schedtool -a 0xf -e chroot . /bin/bash jinks / # ls bin   dev  home  lib32  media  opt   root  sbin  tmp  var boot  etc  lib   lib64  mnt    proc  run   sys   usr jinks / # exit exit jinks /disco2/chroot/amd64 #
And it is stable.
A bit more of information:
# uname -a; qemu-x86_64 --version; gcc --version Linux jinks 4.4.154 #8 SMP Fri Oct 12 00:42:01 CEST 2018 aarch64 GNU/Linux qemu-x86_64 version 2.12.1 Copyright (c) 2003-2017 Fabrice Bellard and the QEMU Project developers gcc (Gentoo 7.3.0-r3 p1.4) 7.3.0 Copyright (C) 2017 Free Software Foundation, Inc. ...
(10-11-2018, 07:32 PM)guannais Wrote: I have tried to emulate a chroot for x86_64 architecture and it gave me inconsistent results, random successes and fails:
And it is stable.
So what is your compiler?
It is GCC 7.3.0.
(10-13-2018, 08:58 AM)guannais Wrote: It is GCC 7.3.0.
Sorry and thanks for that, I haven saw it in above.
I had some problems in the past when I tried to tune compilation process, using both a72 and a53, but not with Quemu..
The Solution I found was , "the common ground", compile for A53..
Then no more problems..
The quemu you are using was compiled by you?
I found some instructions,
https://www.atrixnet.com/compile-qemu-fr...ckinstall/
But they need better tune on configure.ac, they use explicit call, on configure directly..if you tune configure.ac, you could avoid explicit arguments passed to configure.
This is an option, and make some debug, of it.
Probably its duo to A72 being a 3 way superscaler, out of order, with 2 speculative out of order branch's, I think, but I am not sure, about speculation implemented on A72.
I was asking about compiler, because compiler have been receiving a lot of attention because of meltdown and spectre
Compiling it you can have a better, control of whats going on.
Hello guannais,
One thing that ocurred me, looking into gcc 7.3 Documentation..
Try to compile Quemu with:
-march=armv8-a+crc -mtune=cortex-a72.cortex-a53
In this way code will be optimized for Big.Litle cluster..
(11-01-2018, 01:48 PM)tuxd3v Wrote: Hello guannais,
Thanks for the performance advice Smile
Since "qemu" recompiles the code on the fly it may be a problem with the code generator for ARM. What is strange is that any A72 core should be binary compatible with any A53 one, just the armv8-a instruction set.
I was compiling with those flags:
CFLAGS="-march=armv8-a+simd+crc -mtune=cortex-a53 -mfix-cortex-a53-843419 -Os -pipe"
which I inherited from the setup of my Odroid-C2.
Smile
(11-03-2018, 08:43 PM)guannais Wrote: Thanks for the performance advice [Image: smile.png]
You welcome,
In theory,
-march=armv8-a+crypto+crc
Should enable: { "fp asimd" + "aes pmull sha1 sha2" } + { "crc32" }
But if you look into the definitions, that its not clear..
https://code.woboq.org/gcc/gcc/config/aa...s.def.html
So better do a explicit request:
-march=armv8-a+simd+crypto+crc
This should enable: { "fp asimd" } + { "aes pmull sha1 sha2" } + { "crc32" }
not sure about: " evtstrm : kernel event stream using generic architected timer.. "
I think that landed in gcc 8.x, when you use crypto, it already add fp+simd, but I don't know if its already in stable version.. so I tell him explicitly to use the extensions..
  Linux Host - QEMU Android Guest? rik-shaw 0 3,624 07-09-2020, 08:02 PM
Last Post: rik-shaw
  qemu-x86_64 on rockpro? pfremm 3 8,279 05-14-2019, 07:36 AM
Last Post: Crrlow
