How to deactivate kernel output on ttyS2?
I'd like to fully deactivate the console output on ttyS2 as I'd like to use it. How is it possible to do it?
I'm quite new on Linux boards, I4ve try to search for that, understand that there are things to do with the u-boot or equivalent but really didn't find a simple how to to make it possible.
I'm using a Debian version on the RockPro64. The one recommended.
Thanks a lot
Use systemctl [stop|start|enable|disable]
1. Check for getty
$ ps aux | grep getty
root       829  0.0  0.0   3980  1992 ttyS2    Ss+  02:21   0:00 /sbin/agetty -o -p -- \u --keep-baud 115200,38400,9600 ttyS2 vt220
2. Stop getty on ttyS2.
$ sudo systemctl stop serial-getty@ttyS2.service
Repeating the ps command will show that getty is gone, but it will return after reboot.  To persist you can:
3. Disable getty on ttyS2:
$ sudo systemctl disable serial-getty@ttyS2.service
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 3,927 09-22-2023, 04:27 AM
Last Post: diederik
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 4,139 06-16-2023, 10:54 AM
Last Post: CounterPillow
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 4,586 05-13-2023, 12:01 AM
Last Post: swan
  SPDIF output audio gaps jssfr 2 3,347 07-24-2022, 06:26 AM
Last Post: jssfr
  [OS] SkiffOS and Buildroot for Rockpro64 w/ 5.17 kernel paralin1 1 3,354 05-08-2022, 03:26 PM
Last Post: paralin1
  Kernel OOPs triggered by big writes to ext4 FS ajtravis 1 2,855 04-04-2022, 05:29 PM
Last Post: ajtravis
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 3,827 09-11-2021, 08:58 PM
Last Post: t4_4t
  compiling a new kernel for overclocking on arch Mentaluproar 2 4,409 07-15-2021, 10:16 AM
Last Post: Mentaluproar
  Other boot options than Sdcard for linux 5.x kernel? MisterA 2 4,981 07-14-2021, 02:37 PM
Last Post: TRS-80
  ayufan kernel update unbootable TheHunter 2 4,826 03-12-2021, 05:17 PM
Last Post: LMM
