08-27-2018, 02:08 PM
I try with new instalation
after startx
and if i do
sudo /usr/local/sbin/install_desktop.sh
the answer is : Usage: /usr/local/sbin/install_desktop.sh <mate|i3|gnome|xfce4|lxde>
and then i wrote
sudo /usr/local/sbin/install_desktop.sh lxde
and the answer
Unpacking libmali-rk-utgard-450-r7p0:arm64 (1.6-1ayufan7) ...
dpkg: error processing archive /var/cache/apt/archives/libmali-rk-utgard-450-r7p0_1.6-1ayufan7_arm64.deb (--unpack):
trying to overwrite '/usr/lib/aarch64-linux-gnu/libEGL.so.1', which is also in package libegl1-mesa:arm64 13.0.6-1+b2
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any idea?
after startx
rock64@rock64:~$ startx
X.Org X Server 1.19.2
Release Date: 2017-03-02
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.9.0-4-arm64 aarch64 Debian
Current Operating System: Linux rock64 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64
Kernel command line: earlycon=uart8250,mmio32,0xff130000 rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=ea:ef:71:dc:0e:38 eth1addr=ea:ef:71:dc:0e:58 serial=31c7919ddff3362 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4
Build Date: 16 October 2017 08:11:43AM
xorg-server 2:1.19.2-1+deb9u2 (https://www.debian.org/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/home/rock64/.local/share/xorg/Xorg.0.log", Time: Sat Jul 21 21:33:44 2018
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE) armsoc: module ABI major version (20) doesn't match the server's version (23)
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/home/rock64/.local/share/xorg/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
and the answer
Any idea?
