07-21-2018, 06:26 PM
Hi
My pine is unable to boot after sharp power outages causing the pine to lose power.
When I tried to boot and view its output via HDMI, it is stuck.
Is there a way to scan / repair my SD card to save the OS image on it right now? It has configuration for packages on there which took me some time to get right in order to work as I need.
I am running the longsleep build if this information helps.
